Ridgid TS2424-1 ripping issues
Forum topic by rywi posted 04-09-2018 01:06 PM 1770 views 0 times favorited 9 replies Add to Favorites Watch
View rywi's profile
rywi
3 posts in 687 days
04-09-2018 01:06 PM
Topic tags/keywords: tablesaw question
I recently purchased a TS2424 on CL and have been working on getting it dialed in. Both the blade and fence were out of square. I got the fence square and the blade within spec but I noticed that in order to get the belt tight, I have to let the motor hang which tweaks the blade about an 1/16th of an inch. I can account for that by adjusting the trunnions but I’m wondering if there is a better solution, maybe a new belt.
Also as I have been testing it out, when I rip wood (I tried some short pieces of 3/4 plywood) the cut goes well until the very end. I am pushing the board through straight but for some reason the blade catches the wood and knocks the corner off of the end of the board, leaving a less than 90 degree cut on the final 1/2 inch of the board. Thoughts?
9 replies so far
View BlasterStumps's profile
BlasterStumps
1528 posts in 1079 days
#1 posted 04-09-2018 01:24 PM
would seem that something is slightly turning your workpiece as it progresses thru there at the end of cut. Maybe post a picture of the saw showing the blade area, fence and output area.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View Robert's profile
Robert
3639 posts in 2120 days
#2 posted 04-09-2018 01:55 PM
Sequence is 1) blade parallel to miter slot, then 2) blade parallel to fence.
If you set the fence about .003” further away at the back of the blade you will avoid that tear out. Use the same tooth to measure.
As far as the motor hang changing the settings, that may be the saw. That type saw is not going to be made to the tightest tolerances.
Good luck.
View John Smith's profile
John Smith
2196 posts in 802 days
#3 posted 04-09-2018 01:57 PM
are you using a splitter or riving knife that could possible be out of alignment or not the correct one ?
when purchasing used or second hand machines, there is no telling what the P/O has done to it.
-- Failure is proof that you at least tried ~ now, go do it again, and again, until you get it right --
View ChefHDAN's profile
ChefHDAN
1529 posts in 3489 days
#4 posted 04-09-2018 03:01 PM
I think you need to look at your technique and the tools you’re using for measurements. I’ve got the same saw, and have it dead nut square. Kelly Mehler's table saw book was a great help to me, especially since he uses the saw in his diagrams. I used the combo square first, then got a dial indicator, and finally got the woodpecker saw gauge when it went on sale one year. If it wasn’t so expensive I might have bought it sooner, and wish I had, super simple to get very accurate readings and not fuss around.
View rywi's profile
rywi
3 posts in 687 days
#5 posted 04-10-2018 05:28 AM
Thanks for the input guys. I was able to get the blade square, writhing the tolerances of the manual, being careful to make sure it didn’t move as I tightened the bolts. I also tried moving the fence about a 32nd to 16th out over the length of the entire fence and that seemed to fix the tear out issue.
View Loren's profile
10477 posts in 4287 days
#6 posted 04-10-2018 06:14 AM
http://www.in-lineindustries.com/products/contractor-saw-pals/
Some people install grade 8 bolts in the trunnions
and feel that helps.
ChefHDAN
#7 posted 04-10-2018 01:38 PM
- rywi
But now your cuts are not square, I forgot to ask about the blade, what are you running and/or is it the one that came on the saw. I’ve got mine set square front & back, I really think your issue is more of either blade or maybe your push stick use. I had a ZC throat plate that was a bit flexible and if I was applying downforce with my push stick the plate would flex and the end of the cut could catch slightly.
View rywi's profile
rywi
3 posts in 687 days
#8 posted 04-10-2018 02:04 PM
But now your cuts are not square, I forgot to ask about the blade, what are you running and/or is it the one that came on the saw. I ve got mine set square front & back, I really think your issue is more of either blade or maybe your push stick use. I had a ZC throat plate that was a bit flexible and if I was applying downforce with my push stick the plate would flex and the end of the cut could catch slightly.
- ChefHDAN
I am running a Frued thin kerf blade, 50 tooth with the stock throat plate. I have a dial indicator on order so the blade is as straight as I can get it with a combo square. I will have to measure some cuts tonight and see if they are square or not. So far it’s the only way I haven’t gotten tear out
ChefHDAN
#9 posted 04-10-2018 05:07 PM
Yeah, it’s kind of a PITA to do it with a combo, I think you’ll get a better result with an indicator I run the same combo blade, but I do also have a zero clearance plate for it, which reduces the tear out, the CR 1 version here is really nice has no flex in it.
If it’s your first saw there’s lots to learn and the best way is by knowing how to use it safely then get to using it, all projects eventually come down to jigs and boxes… lol
