Delta unisaw arbor rebuikd
Forum topic by hkmiller posted 04-08-2018 01:04 AM 747 views 0 times favorited 5 replies Add to Favorites Watch
View hkmiller's profile
hkmiller
189 posts in 693 days
04-08-2018 01:04 AM
I could not get the the l the lock washer inside the bearing retaining nut the diameter was too large you think this will be a problem?
-- always something
5 replies so far
View CaptainKlutz's profile (online now)
CaptainKlutz
2282 posts in 2106 days
#1 posted 04-08-2018 01:29 AM
That is not a lock washer.
You need to use that washer as designed, or you will be rebuilding the arbor again very soon.
That thrust washer keeps the nut from rubbing on the bearing center race. Without it, the face/edges of nut will abrade the bearing, creating metal shavings, or worse exposing the bearings as it rips up the bearing shield.
Did you damage anything during disassembly and leave burrs somewhere, creating interference?
Unless you replaced the arbor, or bearing retaining nut; that washer should fit?
hkmiller
#2 posted 04-08-2018 01:31 AM
- CaptainKlutz
everything is new to the Arbors new the bearings are new the retaining washer is new in the retaining lock washer is new all ordered from Delta that retaining nut supposed to fit inside the excuse me the retaining washer supposed to fit inside the retaining nut at the diameter of the retaining nut is a little large to fit in there should I grind it down so it will fit
-- always something
View MrUnix's profile
MrUnix
7602 posts in 2810 days
#3 posted 04-08-2018 03:21 AM
- CaptainKlutz
Sorry, but it absolutely is… the washer engages in the key slot and then part of it is bent up to lock the arbor nut from spinning. However, IIRC, it goes on before the outer spanning nut, which is already installed in the photo.
hkmiller
#4 posted 04-08-2018 12:14 PM
- CaptainKlutz
- MrUnix
Brad,
Attchached is the exploded view showing how the arbor parts go together. It shows the lock washer goes in after the bearing retaining/spanning nut.
-- always something
hkmiller
#5 posted 04-09-2018 03:19 PM
This is what I ended up doing. Bent the sides of lock nut onto the nut to hold nut in place.
-- always something
