Making a straight edge with my shaper
« back to Joinery forum
Forum topic by Pizzadave posted 04-07-2018 06:05 PM 982 views 0 times favorited 10 replies Add to Favorites Watch
View Pizzadave's profile
Pizzadave
125 posts in 1050 days
04-07-2018 06:05 PM
Topic tags/keywords: jointingshaper
Hello all, I need to make a straight edge on some 12-14 ft. boards for moulding on a basement project. My jointer will work(obviously) but I wanted to use my shaper with a power feeder. I have the correct cutter to do this but I was wondering on the steps required to have a good result. Not finding a lot on line. Any thoughts?
-- Dave, NY, It works-It really does!
10 replies so far
View John Smith's profile
John Smith
2817 posts in 1130 days
#1 posted 04-07-2018 06:22 PM
I would think the same applies as to a floor mounted jointer:
prepare a 14 foot outfeed table with a 14 foot straight board clamped
parallel with the shaper fence so it will track true all the way out.
featherboards here and there would be a good idea also.
jus my Dos Centavos
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View Rich's profile
Rich
6388 posts in 1557 days
#2 posted 04-07-2018 09:04 PM
- Pizzadave
Set up properly with the outfeed fence even with the bit, you can get a perfectly straight cut. The advantage of doing that versus using rollers on your jointer is that any sag from the rollers not being perfectly flush with the height of the bed won’t transfer to the face of the cut.
View Loren's profile
10921 posts in 4615 days
#3 posted 04-07-2018 10:09 PM
There’s guys on owwm.org who’ve done all sorts
of stuff like that. You could ask there.
I think the general idea of making an outfeed table
and long fence is the way to go. Whether its
work the hassle of the build is another matter.
You could have the stock ripped straight on a
straight line rip saw if you could find a local shop
with one, but I understand the inclination to figure
it out for oneself. I think the slr saws cut straight
enough for glue joints if they’re adjusted properly.
Pizzadave
#4 posted 04-08-2018 06:50 AM
Thanks everyone
View Klondikecraftsman's profile
Klondikecraftsman
52 posts in 1020 days
#5 posted 04-08-2018 12:00 PM
You will have to watch the grain orientation carefully as chip out will be an issue. Several light passes and patience.
-- It is a sin to covet your neighbor’s wife, but his woodpile is fair game.
View cabmaker's profile
cabmaker
1745 posts in 3777 days
#6 posted 04-08-2018 12:57 PM
Dave,,,,, attempting to straight-line on a shaper will be a futile endeavor ,,,,with or without a feeder
I can’t imagine a basement molding project,, as you call it,,,would have enough molding to even attempt such a feat
I t is possible however….what is the table size on shaper,,, 3 or 4 wheel feeder,,,,beginning stock size ? or is it random ?
If it is random widths, that compounds the setup issues
Pizzadave
#7 posted 04-08-2018 03:18 PM
Well. I milled logs from my woods and dried them. I made many pine planks with v tounge and groove for a half wall. I have enough board feet to custom make my trim and baseboard. The baseboard boards are not very straight and I wanted to keep them as long as possible for the longer walls. I was thinking I could use a joint cutter to make them straight. I’ve done many projects on my shaper but never tried to mill long boards to a straight edge. Hoping to get some experience on how other went about this. I don’t want to buy baseboard only because it would take away from the uniqueness of the project.
Pizzadave
#8 posted 04-08-2018 03:20 PM
John Smith
#9 posted 04-08-2018 05:07 PM
Dave ~ That’s some good looking lumber !!
Pizzadave
#10 posted 04-08-2018 05:20 PM
Thanks man! There’s something special about cutting up a tree and bringing into your home.
