Clamp carriers/ racks
Forum topic by PDAWOODWORK posted 04-07-2018 03:01 PM 1373 views 1 time favorited 4 replies Add to Favorites Watch
View PDAWOODWORK's profile
PDAWOODWORK
1 post in 658 days
04-07-2018 03:01 PM
Topic tags/keywords: clamping clamp rack clamp carrier edge gluing glue ups joining gluing
Hey All,
I run a small production shop, we make a lot of cutting boards and serving pieces for hotel and restaurant groups. Over the past 6 months production has increased significantly, just this year we have done over 500 glued up boards. I glue up my panels with pipe clamps and cauls, and even with the crazy number of clamps I have, it is still a tedious process.
Ive been looking into some ways to speed up this process a bit, and have come across these clamp racks and clamp carriers. Doucet and JLT are pretty much the only companies I’ve found that make these kind of systems. Seems to be a rather niche market. I was wondering if anyone has had some experience with these things or any insight into other options
Cheers
Josh
View AlmostRetired's profile
AlmostRetired
220 posts in 1322 days
#1 posted 04-07-2018 04:54 PM
Ever thought about making a large scale jig of some kind? I was making a few a week for a bit and got a hair up my @$$ and made this. Made easy work of the job with a little tweaking.
Good luck and congrats on a growing business.
Roger
View darthford's profile
darthford
612 posts in 2532 days
#2 posted 04-07-2018 06:13 PM
500 dang, how about a rotating pneumatic clamping jig? http://www.jamesltaylor.com/5_section_dp
View Loren's profile
10477 posts in 4256 days
#3 posted 04-07-2018 06:43 PM
You can pick them up cheap at auctions. There
are manual ones and pneumatic ones. If you
have the space and will to move the machine to
your shop it could be a great solution for you.
Check out radio frequency gluing as well. You
put the clamps on, zap the glue-with the
machine for 2 minutes or whatever, take
the clamps off and move on to the next glue-up.
The machine heats up the wood which cures
rf-compatible glue.
I have a Plano clamp which is kind of fussy to
set up for a given width but once it is set up
clamping goes very well. It clamps the faces
flat as well, like cauls, so less machining after
is needed. There’s a knockoff made by Peachtree
that looks identical.
Pneumatic cylinders are not very costly. If you’re
up to doing a little engineering a flat welded or
80/20 frame with cylinders on one side and a
movable fence on the other could take the clamp
handle turning out of your process.
View Tony_S's profile
Tony_S
1067 posts in 3691 days
#4 posted 04-07-2018 08:19 PM
- Loren
This.
I wouldn’t even consider buying a clamp carrier or rack new.
Either auctions, or used machinery places/sites. You can find them in pretty decent shape for a fraction of the price of new.
I’ve got an 18’ JLT for longer glueups up against a wall, and a JLT 12’ Carrier. Good solid units. Nothing wrong with Doucet either. Very similar systems and clamps. Side by side quality from what I’ve seen/used.
Lobo is another name/manufacturer. I can’t speak of the quality of their machines.
-- “Wise men speak because they have something to say; fools because they have to say something.” – Plato
