Effect of Pressure Treated Lumber on Blades
Forum topic by CRAIGCLICK posted 04-05-2018 09:54 PM 829 views 0 times favorited 10 replies Add to Favorites Watch
View CRAIGCLICK's profile
CRAIGCLICK
117 posts in 679 days
04-05-2018 09:54 PM
I am embarking on a shelving project and will require use of a dado blade on PT lumber.
I am a newbie when it comes to working with treated lumber (and to woodworking in general) and I am very afraid of messing up my expensive dado blade. Am I OK using for that purpose, or should I figure out another way?
Thank you in advance for your help with what’s probably a dumb question.
-- Somewhere between raising hell and amazing grace.
10 replies so far
View Bill White's profile
Bill White
5242 posts in 4566 days
#1 posted 04-05-2018 10:09 PM
Wash ‘em good and lube after ya use them.
I use Simple Green.
-- [email protected]
View gargey's profile
gargey
1013 posts in 1381 days
#2 posted 04-05-2018 10:09 PM
Dunno about blunting but remember its toxic. Don’t breathe the dust.
View Klondikecraftsman's profile
Klondikecraftsman
52 posts in 658 days
#3 posted 04-05-2018 10:52 PM
It will be no different than untreated lumber. Wear minimum N95 dust mask, no facial hair. You will need to treat the wood in the dado or it will void the treatment warranty and will rot.
-- It is a sin to covet your neighbor’s wife, but his woodpile is fair game.
View John Smith's profile
John Smith
2133 posts in 768 days
#4 posted 04-05-2018 11:14 PM
outdoor shelving project with P/T lumber?? sketches would help with accurate feedback.
I have made hundreds and hundreds of cuts on 4×4 and 6×6” P/T posts
with my 12” Dewalt miter saw and never washed it after use.
some posts were wet and soggy fresh from the plant and some bone dry.
I noticed no difference in blade wear or pitch build up between P/T wood, hard pine or oak
and miscellaneous aluminum extrusions using stacked dado blades.
when I worked for Lockheed-Martin, I cut hundreds of 7/8” dado cuts on P/T posts
for skids where the 3/4” steel bandings go.
as far as the blade condition goes, if it makes you feel better, wash it and oil it after use.
+2 on the respiratory precautions and safety glasses.
dispose of the P/T sawdust in the regular trash – not in the wood or yard waste recycle bins.
-- I am a painter. That's what I do. I paint things --
CRAIGCLICK
#5 posted 04-06-2018 03:26 PM
Thank you for your replies.
In retrospect, I think PT would be overkill in my application. I am going to build shelving for my garage and was planning on using PT 4×4 (or sistered 2×4) as vertical supports from floor to ceiling. I was considering PT because the wood would come into direct contact with my garage floor, but my garage is dry and reasonably bug-free.
I don’t have any drawings because I’m just shaking the idea out in my brain right now, but the plan is to use the 4×4 on the front and rear of the shelving and dado three sides for notched plywood to fit into. That way I have continuous shelves for 22 feet of wall space. Not sure if I’m explaining it clearly or not.
View Kazooman's profile
Kazooman
1408 posts in 2558 days
#6 posted 04-06-2018 04:21 PM
You can get metal or plastic anchors for the posts that will keep them from sitting on the concrete. The anchors can be attached to the floor to keep the posts in position.
View theart's profile
theart
154 posts in 1160 days
#7 posted 04-06-2018 04:37 PM
I don t have any drawings because I m just shaking the idea out in my brain right now, but the plan is to use the 4×4 on the front and rear of the shelving and dado three sides for notched plywood to fit into. That way I have continuous shelves for 22 feet of wall space. Not sure if I m explaining it clearly or not.
I’m guessing that you want to notch the shelves so that they fit flush to the wall in the back? Unless you’re going to break that up into a bunch of really short spans (<18>) plywood shelves are going to sag badly. I would frame the bottoms of the shelves with vertical 2×4. The 2×4s sit tightly in the dados, then the plywood sits on top with notches to get around the posts.
And PT is definitely overkill. You cold use some specialized standoffs or just some landscape pavers to keep the wood off of the ground.
CRAIGCLICK
#8 posted 04-06-2018 04:57 PM
I m guessing that you want to notch the shelves so that they fit flush to the wall in the back? Unless you re going to break that up into a bunch of really short spans () plywood shelves are going to sag badly. I would frame the bottoms of the shelves with vertical 2×4. The 2×4s sit tightly in the dados, then the plywood sits on top with notches to get around the posts.
- theart
That makes sense. I didn’t really consider sag, so I was just going to use the plywood. And yes, I was wanting to notch the shelves so that they fit against the wall.
The 2×4 will also give me something to anchor against the wall.
View LesB's profile
LesB
2308 posts in 4049 days
#9 posted 04-06-2018 05:04 PM
There are a couple of ways to deal with the possible moisture problem coming from the cement floor. Easiest is to put a piece of asphalt roofing material under the posts. Next is a metal plate or there are metal post supports that are constructed with about a 1/2” air space built in which is even better.
-- Les B, Oregon
View ChefHDAN's profile
ChefHDAN
1496 posts in 3455 days
#10 posted 04-06-2018 07:57 PM
FWIW, and depending on what sort of weight you’re planning to store on the shelves, you’ll lose alot of storage space to the dimensions of the lumber building with 4×4 & 2×4. There are lot of variables not knowing your design, but I bought a house where the previous owner used 4×4 & 2×4 to shelve the garage, and I replaced it using ripped 2×4 s and had a great deal more usable shelf space. For a couple of the lower shelves that were going to get heavier loads I added a piece of angle iron on the front ledge for rigidity. Just my 2 pennies but you’d be surprised how strong the ripped 2×4s are.
