Drum Sander
Forum topic by BigD184321 posted 04-04-2018 02:31 AM 718 views 0 times favorited 7 replies Add to Favorites Watch
View BigD184321's profile
BigD184321
16 posts in 1245 days
04-04-2018 02:31 AM
Who in cyber space has had an experience with a drum sander from grizzly in the 12 inch or the sixteen inch range. Want to use it for making thin laminate strips to glue together for various projects. Looking at 3 inch wide max to sand down to eighth inch thick. Would also consider other smaller drum sanders. Thanks for the input.
7 replies so far
View Loren's profile
10477 posts in 4259 days
#1 posted 04-04-2018 02:46 AM
Drum sanders look like real simple machines
but manufacturers have a difficult time producing
a quality machine on the lower end of the price
range. I’ve seen horror stories about the Grizzly
12” drum sanders. The old Delta 18” models
also have a bad rep.
I had a Woodmaster 12” drum sander that
ran a 4” diameter drum and had drive rollers
like a planer. It was a solid machine though.
I also had a Performax and it was crazy-making.
Newer designs are better.
View Jim Finn's profile
Jim Finn
2782 posts in 3533 days
#2 posted 04-04-2018 12:55 PM
I once had the Grizzly “baby drum sander” IT is a 12” sander that costs just over $600. I had to replace the $150 motor that powers the feed belt every year I owned it. Just after the warranty ran out. I finally tossed it.
-- No PHD just a DD214 Lubbock Texas
View mnguy's profile
mnguy
292 posts in 4010 days
#3 posted 04-04-2018 01:11 PM
I have the Jet 10” drum sander, open frame so you can sand 20” wide material. It doesn’t have a lot of power, so you have to take 1/64” or 1/32” passes and at low to medium feed speeds. Especially with finer grits. I have had it for over a year and have used it fairly regularly for flattening segmented rings for turnings. It has been very reliable. Changing paper is a bit of a pain, as you will see from online reviews, but I have found it’s not too hard once you get the hang of it. Overall, I would recommend the machine highly.
I have not sanded down at the thicknesses you are looking at, but I believe the Jet would handle it fine.
View GR8HUNTER's profile
GR8HUNTER
6837 posts in 1324 days
#4 posted 04-04-2018 02:18 PM
maybe THIS
View johnstoneb's profile
johnstoneb
3131 posts in 2784 days
#5 posted 04-04-2018 04:27 PM
I have a Grizzly 15” dual drum it will sand down to 1.5mm with no problem. Remember this drum sanders are not thickness planers. You need to stay with about a 1/32 or so cut and multiple passes before lowering the drum or raising the table. Trying for that 1/16 will cause premature wear on the paper, can cause the paper to come loose and or cause burn marks.
I will use the planer down to 1/8” and then multiple passes thru the sander to get to my finish thickness.
-- Bruce, Boise, ID
View Davevand's profile
Davevand
155 posts in 1448 days
#6 posted 04-04-2018 04:46 PM
I have a G0458, if I had it to do over I would have saved a few more dollars and bought a Supermax
View Andybb's profile (online now)
Andybb
2405 posts in 1215 days
#7 posted 04-04-2018 05:29 PM
maybe THIS
- GR8HUNTER
If you like making jigs this might actually be a good option especially since you said the max was 3” wide. Spend a few days making the jig and save yourself a lot of money.
-- Andy - Seattle USA
