slicing with a chainsaw
Forum topic by Karda posted 04-03-2018 08:12 PM 842 views 0 times favorited 20 replies Add to Favorites Watch
View Karda's profile
Karda
1950 posts in 1155 days
04-03-2018 08:12 PM
Hi, I want to slice about an inch from this pice of ash bowl blank. The piece iis 3 to 4 ” thick, how can I hold it so I can cut it with a chainsaw. I would also like to know this so I can slpit thick pieces ’’
20 replies so far
View Loren's profile
10477 posts in 4249 days
#1 posted 04-03-2018 09:59 PM
If you don’t want to keep the 1” thick piece
I think it would be easier to manage the
cut by making several crosscuts 1” deep
with a circular saw and split of the waste
with a chisel.
A long controlled split can be executed with
a shingle froe.
View Lazyman's profile
Lazyman
4468 posts in 1988 days
#2 posted 04-03-2018 10:09 PM
Probably too difficult/dangerous with a chain saw. If you have a bandsaw, cut it to length, ( same as width) and then stand it on end and cut the inch off using the bandsaw. If you are going to be turning on the lathe anyway, use a bowl gouge to turn it away before you hollow it.
View johnstoneb's profile
johnstoneb
3131 posts in 2774 days
#3 posted 04-03-2018 10:13 PM
Chainsaw and that piece of wood is an accident just waiting to happen.
-- Bruce, Boise, ID
View Fresch's profile
Fresch
458 posts in 2522 days
#4 posted 04-03-2018 10:15 PM
Router time
View MrUnix's profile
MrUnix
7576 posts in 2800 days
#5 posted 04-03-2018 10:47 PM
Slice an inch from where? If the end (cross grain), that’s easy. If lengthwise (with the grain), that will be a bit tricky but still doable.
MrUnix
#6 posted 04-03-2018 10:53 PM
Flat face down on top of a tree trunk or large slab – engage felling dogs and go to town.
#7 posted 04-03-2018 11:09 PM
If the face is reasonably flat you could clamp
it to a jig and saw into the ends with the
table saw. Then split it off with wedges
pounded into the kerf or finish it up using
a reciprocating saw. The kerfs do a great
job of guiding the long saw blade.
http://www.instructables.com/id/Resawing-Without-a-Bandsaw/
Karda
#8 posted 04-04-2018 05:12 AM
sorry, I forgot to tell you what I want to cut is the face. The dark streak in the middle is part of the pith and i can see a crack forming. I am hoping to find a way to hold the wood so I can chainsaw it never thought of my table saw. I could also kerf it with my table saw and split with my ax,. thanks for the suggestions. I know the ideal is a bandsaw but mine will only cut to 5 15/16ths
View mahdee's profile
mahdee
4291 posts in 2368 days
#9 posted 04-04-2018 12:25 PM
Set the piece flat face down and mark 1-1/2” from flat end up on all 4 sides. use a chalk line and snap a line from corner to corner. Use your chainsaw and cut series of kerf using the chalk lines as a guide. knock out the chunks with a chisel. You will have half inch to play with while you plane it.
-- earthartandfoods.com
mahdee
#10 posted 04-04-2018 12:32 PM
If all you want to do is to get rid of the crack and keep the bark on the other side, lay it with the bark side down and barely touching the surface with your chainsaw blade, go from right to left to right until the crack is gone.
Lazyman
#11 posted 04-04-2018 02:51 PM
... I know the ideal is a bandsaw but mine will only cut to 5 15/16ths
- Karda
Aren’t you going to cross cut it to less than 5” length’s anyway to mount on the lathe? Cross cut it to length first and then stand it on end to slice the inch off the face using your bandsaw.
And next time, when you initially cut the log, don’t cut it exactly in half. Cut to one side of the pith and then the other “half” may be large enough to do that again for a second cut. A side benefit of that approach is you end up with a slice out of the middle that if you cut it in half (cut out the pith) you actually wind up with 2 quarter sawn rough boards that will be very stable that you can use for something else. If you plan to do this a lot you might want to make a cradle to help hold your logs while you mill them with your chainsaw.
View JollyGreen67's profile
JollyGreen67
1676 posts in 3364 days
#12 posted 04-04-2018 04:55 PM
Circular saw and a chainsaw is looking for a place to cause some real damage to your body !!!
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View yvrdennis's profile
yvrdennis
50 posts in 1678 days
#13 posted 04-04-2018 05:32 PM
If you’re putting it on the lathe why bother? You can remove that material with a gouge faster than you could with jigs or circular saws or whatever.
View tomsteve's profile
tomsteve
986 posts in 1820 days
#14 posted 04-04-2018 06:19 PM
looks like a good job for a handheld planer
View LesB's profile
LesB
2297 posts in 4044 days
#15 posted 04-04-2018 08:04 PM
As you said the problem of cutting this piece with any saw is how to hold it firmly enough to be safe during the cutting process. I have made cuts similar to that with a chain saw but I had it well clamped to a bench and proceeded carefully. You might try clamping it between the top bar of two saw horses (if you have them) or something similar. I have one of those Black & Decker portable work benches with a the two halves that clamp together and I would use that.
When I split log sections like that I usually look for early stage cracks and try to follow them with the cut.
If you are just trying to stop or remove the crack that is developing try filling it with thick CA glue (at least the lower part) Then take it off when you turn the piece on the lathe. With the angle the crack is taking, even if you remove the current visible part, it may continue with further drying. I would start rough turning it soon so it can dry without the stress in the wood.
For safety purposes I like the hand plane idea the best to just remove the crack.
-- Les B, Oregon
