Carriage Bolts for workbench leg levelers
« back to Coffee Lounge forum
Forum topic by EdsCustomWoodCrafts posted 04-03-2018 06:25 PM 1610 views 0 times favorited 6 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
932 posts in 1946 days
04-03-2018 06:25 PM
Topic tags/keywords: carriage bolt levelers t-nut
Hi Everyone
I am just wondering if anyone has used the t-nut with carriage bolts to adjust a workbench so as that it is level..
I have 4 levelers from another bench that I tore down but I need 4 more and I saw this being done on YouTube
I’m just afraid that the head of the carriage bolt would skip and slide on my concrete workshop floor
Thanks
Ed
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown” . Come check out my website for more about what I make and how at www.edscustomwoodcrafts.com
View MrUnix's profile
MrUnix
7582 posts in 2802 days
#1 posted 04-03-2018 07:13 PM
I’ve used them for the leveling pads on a homemade mobile base, but I embedded the head in HDPE (recycled milk jugs) to give them a bit more surface area:
View Steve Peterson's profile
Steve Peterson
413 posts in 3685 days
#2 posted 04-03-2018 07:41 PM
Another option is a fully threaded bolt with a large rubber foot, a washer, and a nut. I am not sure how the rubber feet are labeled, but Home Depot or Lowes sell them. Use the washer and nut to hold the rubber foot in place at the end of the bolt.
A T-nut should work as long as the bolt extends several inches into the leg. Anything less and it could tip over.
-- Steve
View CaptainKlutz's profile
CaptainKlutz
2215 posts in 2097 days
#3 posted 04-04-2018 02:37 PM
Leveling feet are available in many different types/styles and some are even low cost.
Have you look at what MSC or Grainger carry?
View MrRon's profile
MrRon
5810 posts in 3847 days
#4 posted 04-05-2018 04:41 PM
A hex head bolt (cap screw) is better than a carriage. The hex head has more of a flat surface so it won’t “skate” around on a cement floor. I would use a hex head bolt with a hex nut in a tee nut. Once the bench is level, tighten the hex nut against the tee nut to lock it in place. That is how I level my shop furniture.
View AlaskaGuy's profile
AlaskaGuy
5520 posts in 2912 days
#5 posted 04-05-2018 04:42 PM
Yes.
View 000's profile
000
2859 posts in 1502 days
#6 posted 04-05-2018 08:22 PM
I’ve had these for years, .....as you can tell.
Works fine though. No lock nut, but once set I’ve never had to re set them.
