PT?
« back to Woodturning forum
Forum topic by Vicki posted 04-03-2018 05:02 PM 595 views 0 times favorited 4 replies Add to Favorites Watch
View Vicki's profile
Vicki
1124 posts in 3948 days
04-03-2018 05:02 PM
Topic tags/keywords: question
Is it safe to turn today’s PT lumber that doesn’t have the arsenic? I made snowmen that get painted and some 4X4’s I don’t need for anything else.
Thanks
-- Vicki on the Eastern Shore of MD
View ChefHDAN's profile
ChefHDAN
1496 posts in 3454 days
#1 posted 04-03-2018 05:40 PM
I don’t turn, and I know that the current materials are supposed to be “safer” but I always still make sure and wear my respirator, (not just a dust mask) whenever I’m cutting ANY of it, because if sawdust isn’t so great for the body, I can’t imagine any chemical impregnated stuff can be safe.
View Wildwood's profile
Wildwood
2790 posts in 2739 days
#2 posted 04-03-2018 07:48 PM
This 3M sanding mask should work. Safety data sheet below recommends both respirator & glove when working with PT wood! There are more expensive options out there and probably mo-better. Thing about 3M masks and others like it is having the right filters for different application.
https://www.lowes.com/pd/3M-Reusable-Sanding-Valved-Safety-Mask/1000027149
http://greatsouthernwood.com/GSWPCMS/uploadedFiles/YW_MCA_MSDS%2081908.pdf
Have 3M 6000 mask with right filters for spray painting and they also have filters for sanding for that series too. Not sure about one linked above. They keep changing model numbers & mask series on us.
Thing about turning and sanding wood can see dust generated but harmfull microsopic particales floating in air you do see so buy something can afford and maintain locally if possible. Also run your dust collection system while turning & sanding PT wood. A small shop vac with dust bag would help a lot but need to fiddle with hose and tie to lathe and aimed so pick up those dust & microscopic devils.
-- Bill
View Lazyman's profile (online now)
Lazyman
4495 posts in 1991 days
#3 posted 04-03-2018 11:03 PM
I wouldn’t. You don’t want to breath the fungicide impregnated dust. Find another use for the PT lumber or give away.
Vicki
#4 posted 04-04-2018 01:19 AM
Thanks everyone. I figured it was a bad idea. I’ll find something else to se it for.
