Best Material For High End Cabinet Cases
Forum topic by austin350s10 posted 04-03-2018 01:35 PM 1206 views 0 times favorited 17 replies Add to Favorites Watch
View austin350s10's profile
austin350s10
12 posts in 1671 days
04-03-2018 01:35 PM
Topic tags/keywords: question tip
I’m about to start my first kitchen project, after practicing on a vanity and closet first. For my vanity, I ended up using Chinese prefinished plywood. I liked it because I didn’t really want to finish the insides of my cases. However, as you can guess the quality is very poor. None of the sheets were super straight, and chip out was a big problem.
For my closet I used 23/32 Russian birch. I freaking love this stuff, because it cuts like a dream and is straight as a arrow! Also, since I painted my closet white I didn’t really care about it being prefinished.
Now, I’m about to tackle my kitchen carcasses. I’m looking for a superior product that is prefinished. I don’t know why but, I have my heart set on a very light to slightly yellowish maple color. Obviously, I’ll never use Chinese plywood again. Additionally, the Russian birch is out of the picture because, it’s not prefinished.
The more and more I get into woodworking the more I hear people talking about using plywood with MDF cores, or laminate faces instead of veneer (melamine). Then, I start researching the different types of plywood available and my head starts to spin!
I’ve never used anything other than the products I’ve already mentioned here and the junk available from the big box stores. Given the expense of carcass material for a whole kitchen, I want to do it once and do it with the best product currently available.
I’m hoping I can get some advise on what product to use, the name of a good supplier, and any noteworthy tips I could use when it comes to milling the product. I live in lower Michigan and my budget per 4×8 sheet is around $90 if that helps…
17 replies so far
View 01ntrain's profile
01ntrain
259 posts in 2229 days
#1 posted 04-03-2018 02:23 PM
Not really familiar with a “pre-finished” plywood. Not exactly sure if you can find it out there, except through a wholesaler. Cabinet shops have a finishing department, they don’t order in a “pre-finished” sheet of plywood and build their carcass.
Since your budget is pretty high, I would order in Baltic Birch plywood. It normally comes in 3×5 size, in typical thicknesses (1/2, 5/8, 3/4, etc.) but it can be special-ordered in larger sizes. I might check with a local cabinet shop or lumber wholesaler to see what’s available.
If you decide to go with a laminate such as melamine or similar. I would use a combination of Conformat screws (google it) and joinery to reduce chip-out and to make sure that the carcasses are strong. You didn’t mention what kind of tools that you’re using, but I use a track-saw to break down my sheet goods and a table saw with a good plywood finishing blade to cut to dimensional sizes. With that combo, I can reduce the chipout and waste even while using the cheaper plywoods.
View RobHannon's profile
RobHannon
347 posts in 1689 days
#2 posted 04-03-2018 02:30 PM
You should be able to order pre-finished baltic birch if that is the direction you want, but good chance it will run around the top end of your budget unless you are ordering a lot.
View dad2jj82's profile
dad2jj82
42 posts in 2773 days
#3 posted 04-03-2018 02:38 PM
I’m not sure where at in lower Michigan you live? However Johnson’s Workbench in Charlotte sells nicer grades of plywood. They should be able to help you out. They have a list online that you can get a general idea of pricing. It’s a cool store.
View HerbC's profile
HerbC
1820 posts in 4018 days
#4 posted 04-03-2018 02:46 PM
01ntrain, many cabinet shops can get and do use prefinished cabinet grade plywood to make the boxes of their cabinets. The finish applied by the manufacturer is even better (more uniform and durable) that that which would be applied by the shop in their finishing rooms. It’s not cheap, but is reasonable considering the quality and the labor savings. I’m currently in process of building kitchen cabinets to remodel our kitchen and am ordering the plywood through a local cabinet shop. The cost to me will be just a little over $60 (US) per sheet of 3/4” birch, prefinished on both sides. 1/4” for backs and drawer bottoms will run just under $30 per sheet…
OP, good luck with your build. You might want to call around to the local cabinet shops in your area to see if one of them will assist you in procurement…
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View DS's profile
DS
3858 posts in 3579 days
#5 posted 04-03-2018 02:59 PM
We use Thermofused Melamine almost exclusively in our high-end products. TFM is very low maintenance, water resistant and durable and is available in hundreds of prints and finishes.
As for the core itself, straight up Particle Board core is acceptable, but if you are opposed to that, (as some are), a Classic Core plywood, that has the center with lumber plies and the outermost plies are mdf plies, is a very stable and flat/true product and holds screws tight and strong.
And while there are many good prefinished plywood products out there, the typical A grade veneers actually look fake when used in case goods. If you go this route, a B or C grade plywood, which is usually less expensive, actually looks preferable in my opinion.
I would still go with a classic core, even with prefinished veneers.
View Robert's profile
Robert
4639 posts in 2639 days
#6 posted 04-03-2018 03:46 PM
No matter what you use, get your materials from a commercial supplier. Personally, I try to get people to go with melamine like DS described. Its a high quality commercial product with particle board core. The stuff at HD is junk.
I’ve also used a plywood core product called Panolam but its more expensive and I don’t think the difference is worth it.
Lots of guys won’t use it but I’ve never had an issue with it even under sink units. The white interior brightens up the inside of a cab, plus its very easy to clean. People like that.
I pretty much go with frameless 32mm system type assembly. Use Confirmat screws and you need a blade specifically for double side melamine.
Edge band to match the face frames.
View AlaskaGuy's profile
AlaskaGuy
6698 posts in 3467 days
#7 posted 04-03-2018 03:52 PM
What does High end mean?
Most any 3/4 Canadian or American made prefinished Maple or Birch plywood will make you a good cabinet box. Russian birch 5×5 sheet are a pain in the ass to handle until you first cut is made. That or I have short arms and the don’t fit in my truck very well either. Just not worth it to me.
View PPK's profile
PPK
1861 posts in 1968 days
#8 posted 04-03-2018 04:05 PM
I second what DS said. I personally like the “composite” sheets that have a couple layers of MDF right under the finish laminates, and then a plywood core. It’s the best of both worlds. At Menards they call if Procore, other local lumber stores call it different names, but it’s exactly what DS shows in his picture.
I really don’t like solid MDF core panels. Too dusty and heavy, and don’t hold fasteners well. The dust is just nasty too.
On the other hand, solid ply core panels tend to be harder to finish with a darker stain, because the surface under the final laminate can tend to be a little uneven due to the wood grain. I know this all from unfortunate experience!
-- Pete
austin350s10
#9 posted 04-03-2018 05:32 PM
- DS
DS you said to go with Classic Core, which I feel would work better anyway. Are you sill able to use regular pocket hole screws with the Classic Core TFM? I build my cases with biscuits and pocket hole screws. Also, I’d imagine I’d have to use a special type of blade to cut TFM, correct?
View DS's profile
DS
#10 posted 04-03-2018 06:02 PM
Yes, Classic Core has all the fastening advantages of plywood with all the fit and finish of mdf.
If you truly are looking for “High End”, this is the stuff – regardless if you use melamine or pre-finished veneer surfaces.
View jonah's profile
jonah
2136 posts in 4457 days
#11 posted 04-03-2018 06:11 PM
If you don’t go the TFM route, go with prefinished maple or birch plywood. I would never build a cabinet out of a material that isn’t prefinished. It’s incredibly convenient and fast, and you only pay like ~20% more for the prefinished stuff over regular birch plywood.
austin350s10
#12 posted 04-03-2018 07:07 PM
Yes, Classic Core has all to fastening advantages of plywood with all the fit and finish of mdf.
- DS
DS There’s a place very close to me that sells the Panolam products you mentioned. I’m going to stop by and check them out soon. Regarding pre-finished veneer surfaces, do you have any vendors you’d suggest checking out?
View DS's profile
DS
#13 posted 04-03-2018 07:42 PM
The only pre-finished I’ve really used is made by States Industries.
They have several very nice products.
Certainly, though, there are several vendors that make/sell this type of product.
View DS's profile
DS
#14 posted 04-03-2018 07:44 PM
... edit – double post … sorry
View bigblockyeti's profile
bigblockyeti
7443 posts in 2879 days
#15 posted 04-03-2018 08:51 PM
3/4” CDX
