Bench top planer
Forum topic by BigD184321 posted 04-02-2018 06:51 PM 1040 views 0 times favorited 18 replies Add to Favorites Watch
View BigD184321's profile
BigD184321
16 posts in 1244 days
04-02-2018 06:51 PM
Need a great recommendation on a bench top planer. Much of what I read it is the Dewalt 735 model. Thanks for sharing.
18 replies so far
View LDO2802's profile
LDO2802
167 posts in 1040 days
#1 posted 04-02-2018 09:45 PM
Are you asking about the Dewalt 735? because that is pretty much the top bench top thickness planer you will find before going to a standalone.
BigD184321
#2 posted 04-02-2018 10:50 PM
Wow I thought I mentioned the Dewalt 735 in my question…Did I miss something?
View Rich's profile
Rich
5153 posts in 1199 days
#3 posted 04-02-2018 11:47 PM
Looked to me like you did mention it in your post. I recently upgraded from an old DW733 that I’d had for about 20 years to the 735. It’s like night and day. The cut is much smoother and it’s a much more solidly built machine. I also like the two feed speeds. It did have more snipe out of the box, but adjusting the extension tables to lift the board on each side reduced that to almost nothing.
View msinc's profile
msinc
567 posts in 1113 days
#4 posted 04-03-2018 03:46 AM
I have had the 735 for a year and a half now. Mine has been put thru the paces. I got the extension tables and the stand for it. My personal opinion is that it works too good to be true!! I have been waiting for mine to blow up, start knocking and throw a rod or something since I got it, it works that good. For the money, there is zero chance you can go wrong. Buy with confidence. There may be others out there that work good for the money, but they cannot be better. DeWalt really hit a home run with this machine as far as I am concerned. Unless someone else has very recently come out with something fantastically better you can stop looking and go get a 735 asap.
View John Smith's profile
John Smith
2135 posts in 772 days
#5 posted 04-03-2018 01:06 PM
there are two DW-735s for sale on C/L in my area – each is almost the price of a new one.
so they must hold their value quite well.
-- I am a painter. That's what I do. I paint things --
View AAL's profile
AAL
82 posts in 2036 days
#6 posted 04-03-2018 01:20 PM
I love my DW735! The blower really does a great job of evacuating the chips, the dual speed is a great feature, and the thickness adjustments are right on. I also set up the infeed & outfeed tables upward ~ 1/8” to eliminate sniping, although I still run pieces through that are longer than need just in case (don’t want to lose a god finished board). Removing/replacing the blades is easy & they locate positively & consistently.
I sharpen the blades (not often they hold up well) myself. I slit a series of parallel grooves on my table saw across a wide, thick stable board to the angle I want (25°/30°) and all to the same depth, place the blades into the slot so they all lay flat, and then run a stone across the top of all three at the same time. Works well.
-- "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery." Winston Churchill
View Steve's profile
Steve
1702 posts in 1192 days
#7 posted 04-03-2018 03:40 PM
I got my 735x during the 20% off ebay sale. $425 shipped. couldn’t pass it up.
View Rich's profile
Rich
#8 posted 04-03-2018 03:54 PM
I got the same eBay deal and sold my 20 year old 733 for $225 on CL, so the upgrade cost was $200. Totally worth it.
View Walker's profile
Walker
197 posts in 1082 days
#9 posted 04-03-2018 04:20 PM
I’ve had success with refurbed tools from CPO. Also keep on eye on Craiglist. I have the DW734 and very happy with it.
https://www.cpopowertools.com/
https://www.factoryauthorizedoutlet.com/brands/dewalt
-- ~Walker
BigD184321
#10 posted 04-03-2018 05:21 PM
What would someone say about the Jet 13” planer/moulder? Is it a good product? With the Dewalt 735x and the Jet how thin can you plane a board. Looking at planning to 1/8” and thinner….
View Rich's profile
Rich
#11 posted 04-03-2018 05:25 PM
- BigD184321
The 735 has a stop at 1/8”. It’s adjustable so you could go thinner, but it’s better to use a sled made from something like 1/2” MDF. You can tack the board to it using hot melt glue and plane as thin as you like. The sled is a safer option because you don’t risk having the blades hit the bottom plate of the planer. Worst case you gouge your sled.
View TheFridge's profile
TheFridge
10859 posts in 2096 days
#12 posted 04-03-2018 05:37 PM
You should temper your expectations before planing stock down to 3/32 – 1/16 thick. At a certain point I do not know, it crosses into the realm of drum/wide belt sanders for thicknessing. I could be wrong but most of my stock 1/8 on down tended to explode in the planer.
View ChefHDAN's profile
ChefHDAN
1499 posts in 3459 days
#13 posted 04-03-2018 05:44 PM
^+1 had a piece of slightly figured cherry go to pieces in my DW735 the other week. Got another piece dimension-ed by hand with a #6. What a god awful sound that made. Dreaming of one day owning a belt sander.
View Rich's profile
Rich
#14 posted 04-03-2018 06:00 PM
Planing thin stock depends a lot on the wood in my experience. I make small lidded boxes and line them with thin pieces that I miter to fit snugly and that stand about 5/16” proud of the bottom of the box to align the lid (no hinges).
I have no trouble at all planing a smooth grained wood like soft maple or basswood down to 1/16”, but some other woods I’ve tried, like ash, just shatter, leaving large gaps in the board.
A drum sander would definitely be a better choice though and would likely perform well on just about any wood. I just don’t have one yet.
View corelz125's profile
corelz125
993 posts in 1586 days
#15 posted 04-03-2018 11:40 PM
Fridge was it alder that exploded?
