replacement pulley for Jointer
Forum topic by CharlesA posted 04-02-2018 01:24 PM 994 views 0 times favorited 14 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3393 posts in 2399 days
04-02-2018 01:24 PM
I have an 1960’s Davis and Wells Jointer. In our move, the drive pulley was damaged. I’ll post a picture and measurements when I have a chance. Short question: what’s a good source for a replacement pulley?
Thanks.
14 replies so far
View Aj2's profile
Aj2
2648 posts in 2400 days
#1 posted 04-02-2018 01:51 PM
Try this place Charles. They have a very good inventory I was able to find a pulley for my Davis and wells tablesaw.
http://www.electricmotorwarehouse.com/pulleys-sheaves/
-- Aj
View CaptainKlutz's profile
CaptainKlutz
2208 posts in 2096 days
#2 posted 04-02-2018 03:35 PM
I have had good luck finding replacement pulleys for lathe and Band-saw repairs at MSC
View WyattCo's profile
WyattCo
93 posts in 706 days
#3 posted 04-02-2018 04:00 PM
Any local industrial supply stores in your area?
View HokieKen's profile
HokieKen
11983 posts in 1740 days
#4 posted 04-02-2018 05:02 PM
Tractor Supply is a good bet if you have one in your area.
-- Kenny, SW VA, Go Hokies!!!
View MrUnix's profile
MrUnix
7579 posts in 2801 days
#5 posted 04-02-2018 05:07 PM
Tractor supply, Graingers, MSC, McMaster Carr, Fastenal, a good hardware store (like ACE), most any motor repair shop, etc… and there are some on-line specality places as well. Unless it’s a stepped pulley or some weird bore size, they are easy to find.
View Ripper70's profile
Ripper70
1368 posts in 1510 days
#6 posted 04-02-2018 05:10 PM
Grainger
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View GR8HUNTER's profile
GR8HUNTER
6797 posts in 1314 days
#7 posted 04-02-2018 05:43 PM
my local hardware store carries them :<))
View Bill White's profile
Bill White
5242 posts in 4562 days
#8 posted 04-02-2018 06:02 PM
What size OD and shaft?
-- [email protected]
View diverlloyd's profile
diverlloyd
3757 posts in 2459 days
#9 posted 04-02-2018 06:05 PM
Rural king
View bc4393's profile
bc4393
86 posts in 1744 days
#10 posted 04-02-2018 07:37 PM
I had a jointer pulley that was vibrating when i rebuilt it, even with new bearings. Bought a used replacement on Ebay, still funky. Then I found an exact replacement size of the TB Woods brand for like 20 bucks. I’ve bought a couple TB Woods pulleys to replace some damaged aluminum one on older delta machinery. I’ve been very impressed. They are painted cast iron though so they are heavier but the finish is nice and they are good and balanced. They didn’t have the exact size I needed for my Delta bandsaw so I ended up buying 2 to get the math right on RPM. Got it closer to 3000 magic SFPM that it originally was so I’m happy. One of em I had to file the inside of the pulley to get it to fit on the shaft but that’s not uncommon.
CharlesA
#11 posted 04-05-2018 11:36 PM
Thanks, everyone. The diameter is 7.5”
Here’s a pic:
View coxhaus's profile
coxhaus
152 posts in 1496 days
#12 posted 04-06-2018 07:13 PM
Wow. Bad luck.
I needed a multi-step pulley for my old Atlas drill press which I could not find. I found the right sized pulley. I had a machine shop close to me cut the center out on a lathe to the right size. I could not find a pulley with the right spindle shaft size.
View Aj2's profile
Aj2
#13 posted 04-06-2018 07:25 PM
That’s a very cool looking pulley have tried calling Davis and wells. Dan might have one he’s helped me with original parts for my tablesaw.
http://www.davisandwells.com/
-- Aj
CaptainKlutz
#14 posted 04-07-2018 02:19 AM
This pulley assembly is call an interchangeable or Quick Detachable pulley.
The hub/flange/bushing and pulley are 2 separate parts.
Tear it down, check for any PN cast on pieces. Measure the hub flange and might find just the pulley.
Maybe Grainger?
Here’s a pic:
- CharlesA
