Craftsman 113.298720 arbor bearing
Forum topic by hkmiller posted 03-30-2018 05:13 PM 1495 views 0 times favorited 4 replies Add to Favorites Watch
View hkmiller's profile
hkmiller
180 posts in 685 days
03-30-2018 05:13 PM
Was given this saw yesterday and there is some play in the arbor.
So, I might need to replace the bearing.
I did some searches on this forum and web, and I came up with this item:
620210 ZZ C3 Nachi Bearing JAPAN 5/8 ID X 35mm X 11mm 6202-10 DOUBLE SHIELDED .625
Anybody here think this would be the one to get?
I got the Nachi brand for my 34-450 unisaw. I like the Japanese made bearing.
-- always something
View MrUnix's profile
MrUnix
7582 posts in 2802 days
#1 posted 03-30-2018 05:55 PM
I know that many, if not most, of the old Emerson saws used bearings with 5/8” bores, so the 6202-5/8 is probably a good bet – however, I would yank the ones you have first before ordering just to make sure. And yes, Nachi is a quality bearing on par with any of the other top-tier bearing companies. For reference, I just ordered some a few weeks ago from Accurate Bearing for an Atlas/C-man drill press I’m restoring… and they were around $6 a piece… a bit more than the standard 6202 due to the odd I.D.
hkmiller
#2 posted 03-30-2018 06:02 PM
I know that many, if not most, of the old Emerson saws used bearings with 5/8” bores, so the 6202-5/8 is probably a good bet – however, I would yank the ones you have first before ordering just to make sure. And yes, Nachi is a quality bearing on par with any of the other top-tier bearing companies. For reference, I just ordered some a few weeks ago from Accurate Bearing for an Atlas/C-man drill press I m restoring… and they were around $6 a piece… a bit more than the standard 6202 due to the odd I.D.
- MrUnix
Brad, that’s a great price would that be the equivalent bearing of the one I posted in the original question
-- always something
MrUnix
#3 posted 03-30-2018 06:47 PM
Brad, that s a great price would that be the equivalent bearing of the one I posted in the original question
- hkmiller
Yes. Standard sealed 6202 with a 5/8” bore.
hkmiller
#4 posted 03-30-2018 07:00 PM
- hkmiller
- MrUnix
Great thanks for getting back
-- always something
