Gluing to shellac?
Forum topic by AESamuel posted 03-28-2018 05:42 PM 1321 views 0 times favorited 7 replies Add to Favorites Watch
View AESamuel's profile
AESamuel
105 posts in 2102 days
03-28-2018 05:42 PM
Hi,
I want to glue a thin peice of felt into the bottom of a jewellery box I’ve made and finished with shellac, and was wondering what glue to use. Would regular yellow glue work as it’s pva?
Many thanks!
7 replies so far
View Loren's profile
10689 posts in 4528 days
#1 posted 03-28-2018 05:48 PM
For gluing fabric to wood spray adhesive is
easiest. With PVA I’d be concerned about the
wet glue soaking into the felt and making hard
spots in it.
You could also use double sided carpet tape
all over the bottom. It’s useful tape for woodworking
anyway. While spray adhesive is great for
gluing down fabric the overspray is messy and
the sprayer on the can gets clogged easily.
View LesB's profile
LesB
2620 posts in 4323 days
#2 posted 03-28-2018 06:21 PM
Most craft stores carry self adhesive felt sheets that work well. I have used them inside and out side of boxes.
Otherwise I would agree with spray adhesive.
-- Les B, Oregon
View ScottM's profile
ScottM
748 posts in 3026 days
#3 posted 03-28-2018 06:23 PM
I just bought peel and stick sheets of felt from Amazon. Works great and it’s easier than trying to glue it.
View Woodknack's profile
Woodknack
13503 posts in 3260 days
#4 posted 03-28-2018 06:29 PM
Spray glue or flocking.
Or the self adhesive felt is enticing, I’ll have to look for it.
View RobHannon's profile
RobHannon
347 posts in 1410 days
#5 posted 03-28-2018 06:30 PM
For felt, Aleene’s Tacky Spray or peel and stick if the size was right would be my choice. Carpet tape may work too but I don’t know if I would go that route if it was a big area or if I had to do a lot of them.
View dalepage's profile
dalepage
387 posts in 1720 days
#6 posted 03-28-2018 07:53 PM
Don’t glue!!
You can buy adhesive-backed felt at many hobby stores and on line.
It’s so much easier to work with the felt with a backing when you are measuring. Before you remove the paper and expose the adhesive side, you drop it into the box and check the fit. Remember the orientation. Then pull back only half the paper and cut it off. Now put the felt, NON-STICKY side, into place. Carefully roll the sticky side onto the empty space. Press down with a rubber spatula. Lift the non-sticky side and pull off the paper. Then carefully roll it into place.
It works great if you measure carefully and fully the above procedure. I used it lately on all four sides and the bottom of a cherry box. It was great with hunter green felt.
-- Dale
AESamuel
#7 posted 03-28-2018 09:49 PM
The self adhesive stuff sounds good, I’ll check out my local hobby store and see if they have any. Thanks a lot!
