Trick for helping purple heart color come out faster
Forum topic by Drumn2121 posted 03-28-2018 05:12 AM 659 views 0 times favorited 6 replies Add to Favorites Watch
View Drumn2121's profile
Drumn2121
18 posts in 789 days
03-28-2018 05:12 AM
The pictures don’t do it enough justice but I have found that if you don’t want to leave it outside to color up you can use black lights to do it. I went to Walmart and bought a couple cheap light bulbs and put them in a spot lamp. This is over the course of 4 days on one side only. The first picture is the side not under the lights and the second is the side they were shining on.
View WyattCo's profile
WyattCo
93 posts in 706 days
#1 posted 03-28-2018 11:29 AM
15 to 20 minutes in the sun. That’s all that needed.
View AlmostRetired's profile
AlmostRetired
220 posts in 1316 days
#2 posted 03-28-2018 06:22 PM
I have used a heat gun in the past to make the color pop after sanding. Helped a ton!
Drumn2121
#3 posted 03-28-2018 07:16 PM
Does the heat gun have much effect on the other woods?
View dalepage's profile
dalepage
385 posts in 1442 days
#4 posted 03-28-2018 07:46 PM
Thanks! I have a nice piece of purple heart for a box and will use your technique. I appreciate your posting this.
-- Dale
WyattCo
#5 posted 03-28-2018 08:56 PM
Guys, it’s photosynthesis, not brain surgery. It just wants UV.
View splintergroup's profile
splintergroup
3194 posts in 1824 days
#6 posted 03-28-2018 09:41 PM
Much faster with a UV-B light (fingernail polish dryer) or UV-C (pond sterilizer).
Of course some PH will completely ignore your attempts.
