Delta 28-200 restoration help
Forum topic by LucasWoods posted 03-27-2018 02:35 AM 451 views 0 times favorited 3 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
448 posts in 1934 days
03-27-2018 02:35 AM
I have never worked on a bandsaw or operated one.
What do I need to check on these when restoring it?
I checked the tires and bearings it seems all of them need replacing.
Is there anything else I need to check that typically broke or did not operate well?
-- Colorado Springs, CO - USAF
3 replies so far
View MrUnix's profile
MrUnix
7576 posts in 2800 days
#1 posted 03-27-2018 02:37 AM
Upper wheel hinge is about the only weak link. Make sure it’s not bent or cracked.
Other than bearings, tires and probably a belt, everything else is pretty much bullet proof.
I’d replace the bearings in the motor while you are at it.
LucasWoods
#2 posted 03-27-2018 02:49 AM
Do I need a special bearing press to do that myself or should I take the motor to an electric motor shop?
MrUnix
#3 posted 03-27-2018 03:02 AM
I’ve never needed a press. A 3-jaw puller and/or bearing splitter helps with removal, but isn’t usually required as there are plenty of ways to get them off without one. Putting them on usually just involves an appropriate sized pipe or deep well socket and a hammer. Pull the motor apart and see what bearings you need so you can order them all at the same time… and don’t forget a couple of 6200’s (guide thrust bearings).
