Goodell-Pratt miter box disassembly: are these rivets?
« back to Hand Tools forum
Forum topic by Holbs posted 03-26-2018 02:32 AM 546 views 0 times favorited 9 replies Add to Favorites Watch
View Holbs's profile
Holbs
2262 posts in 2637 days
03-26-2018 02:32 AM
I am in the midst of tearing down and rehabbing a $10 Goodell-Pratt miter box that came with a Disston “made for Goodell-Pratt” 5×30” miter saw (pretty sure that is the saw measurements).
Have it nearly all taken apart except for the table webbing and the …fulcrum ””T”” connection. Are these rivets for old yonder days, that are in the webbing? They are not slotted like the other flatheads but rounded over smooth and flush to the opposite side.
And I have no idea how to remove the fulcrum ””T”” bar/screw (if it’s even a screw) under the release level assembly. Was debating on WD-40, then really cranking down on vice grips or something, but then thought that always gets me into trouble :)
Any help?
9 replies so far
View Woodknack's profile
Woodknack
13017 posts in 2988 days
#1 posted 03-26-2018 03:07 AM
Top one looks like a (edit: drive screw), second one looks like a roll pin. I’ve never taken the former apart but I think you just pry or drill them out and replace them. Latter is driven out.
Holbs
#2 posted 03-26-2018 03:10 AM
blind rivet… that’s a new one for me. If I drill it out, can be replace with a new blind rivet? I have the newer tech of pop rivet & gun :) Something tells me, these blind rivets were more robust. Just watched a youtube vid… these are not the “pop rivet” type as nowaday rivets leave material on the blind side. These rivets are flush. Hmm…
Roll pin… ok. Will try to punch it out with my pin punches.
Woodknack
#3 posted 03-26-2018 03:13 AM
Sorry, you were too quick. I looked it up and I had the wrong name, it’s a drive screw. (I think that’s what they are)
Holbs
#4 posted 03-26-2018 03:15 AM
yep…they look like drive screws.
Woodknack
#5 posted 03-26-2018 03:16 AM
I also have a Goodell Miter saw but have never taken it apart. There are a few other guys around here that have them, hopefully one will chime in and confirm or correct me.
Holbs
#6 posted 03-26-2018 03:19 AM
How the heck did they use drive screws in the webbing? You need a hammer to whack these guys from the inside webbing to outside. Hmm… really want to take out the webbings and clean everything but maybe leave webbings in place.
Smitty_Cabinetshop
16341 posts in 3226 days
#7 posted 03-26-2018 11:57 AM
For the integrity of the box, I’d leave them in place.
View theoldfart's profile
theoldfart
11057 posts in 3059 days
#8 posted 03-26-2018 12:40 PM
I’ll second Smitty, Goodell must have used a jig to hold everything in place and properly aligned when they originally made the unit.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
Holbs
#9 posted 03-27-2018 12:28 AM
yep, I’ll leave webbing & drive screws in place.
