help finding parts
Forum topic by jrthekid posted 03-23-2018 02:35 PM 280 views 0 times favorited 2 replies Add to Favorites Watch
View jrthekid's profile
jrthekid
8 posts in 1539 days
03-23-2018 02:35 PM
Topic tags/keywords: question
try to make this short, need new chuck for my old rockwell 32” 11-280 drill press sn gm 7311. went to you tube showed how to drop chuck by hitting something in the holes in front. when it did not drop , I turned to old school got my hammer and crowbar and got it out. but the shaft also. the chuck and shaft will not come apart. 1 is this right, 2 do I need a chuck with the shaft. or am I not doing this right. by the way if you look at my profile, I,m new to shop work.thank you for any help.
2 replies so far
MrUnix
7579 posts in 2800 days
#1 posted 03-23-2018 02:51 PM
According to the manual/parts diagram, that press uses a pretty standard Jacobs chuck with a JT-33 taper – it should pop off with a bit of persuasion. The spindle is also easily removable, but you certainly did it the wrong way :(
View TheFridge's profile
TheFridge
10859 posts in 2088 days
#2 posted 03-23-2018 03:09 PM
Chuck wedges. They’re cheap. Or make your own with some scrap and a grinder.
They is usually a hole in the spindle to knock the arbor with chuck attached out with a wedge. Once that’s out. Then you separate with chuck wedges.
