Need help on 1995 powermatic planer
Forum topic by Pizzadave posted 03-11-2018 01:14 AM 509 views 0 times favorited 4 replies Add to Favorites Watch
View Pizzadave's profile
Pizzadave
125 posts in 1005 days
03-11-2018 01:14 AM
Topic tags/keywords: powermatic 1995 planer lubrication
Hi gang. I am confused on the necessary lubrication on the used plane I just got. It’s a 1995 powermatic 15. The pics show the gear box. I get that except how much oil to put in. The other question I had was, these plated on both sides of the planer top are saying to lubricate with light oil and arrows pointing. All I see on one side are the tension spring screws and the other has 2 smaller screws with an Allen fitting? Do I oil more than the gear box?
-- Dave, NY, It works-It really does!
View Holbs's profile
Holbs
2373 posts in 2952 days
#1 posted 03-11-2018 07:03 PM
yep. you are suppose to put a drop of oil various places to keep things lubricated. Best consult owners manual.
Pizzadave
#2 posted 03-11-2018 08:00 PM
Thanks. Manual only says to chasing gear box ool. Nothing else.
Holbs
#3 posted 03-11-2018 08:06 PM
Hmm.. my Jet 15” planer manual says to put drops of oil various places. I could only assume, your PM 15” should be similar.
Pizzadave
#4 posted 03-11-2018 08:28 PM
Thanks for the help. I’ll check it out.
