My compressor wont build pressure
Forum topic by HelpMe posted 03-08-2018 07:35 PM 388 views 0 times favorited 4 replies Add to Favorites Watch
View HelpMe's profile
HelpMe
1 post in 686 days
03-08-2018 07:35 PM
Hello,
Am new here and needing some help , my compressor runs fine but wont build any pressure , its older and I believe its a FINI brand , I will try to upload a few pics , the blue arrow is pointing to where the air seems to be exiting instead of filling the tank , any help is very much appreciated …
Cheers
MrUnix
7587 posts in 2804 days
#1 posted 03-08-2018 07:46 PM
Looks like an overpressure release valve – which is probably stuck. If you have the manual, check the parts diagram. You could also contact the company directly and just ask them :)
Rick Dennington
6789 posts in 3800 days
#2 posted 03-08-2018 07:58 PM
Go to Youtube, and type in “my compressor won’t build up pressure”...There are several youtube videos to tell or show you how to fix the problem…..
-- " There's a better way.....find it"...... Thomas Edison.
View John Smith's profile
John Smith
2133 posts in 768 days
#3 posted 03-08-2018 09:55 PM
did you spray some soapy water on all the connections ?
if any fitting is the culprit, it will produce bubbles like a leak in a tire.
have you been tinkering with any of the adjustments under the gray plastic cap ??
-- I am a painter. That's what I do. I paint things --
View bigblockyeti's profile (online now)
bigblockyeti
6184 posts in 2326 days
#4 posted 03-08-2018 10:15 PM
That looks like a cold start valve to me, occasionally they’ll stick open and you’ll never get past 10-15psi from a completely empty tank. You can remove it and clean out any dust or tiny debris or get a new one for under $10.
