Variable motor
Forum topic by woodworm1962 posted 03-04-2018 04:04 PM 762 views 0 times favorited 15 replies Add to Favorites Watch
View woodworm1962's profile
woodworm1962
145 posts in 704 days
03-04-2018 04:04 PM
I am looking for a 120 volt Motor that has variable speed that I can use to make make shift large lathe and other stuff with. So will need pullies and belts and bearing as well
Any advise
-- No one likes the truth...
15 replies so far
View Ripper70's profile
Ripper70
1368 posts in 1512 days
#1 posted 03-04-2018 04:13 PM
I’ve seen allot of those kinds of projects that use treadmill motors. You can usually find treadmills for sale on CL pretty cheap or, sometimes, people give them away just to get rid of them. DC motors up tp 2.5 h.p. are pretty common.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
woodworm1962
#2 posted 03-04-2018 07:21 PM
WOW thanks… BUT what is the point of having a MOTORIZED treadmill???? ARent you suppose to do the work?
I ve seen allot of those kinds of projects that use treadmill motors. You can usually find treadmills for sale on CL pretty cheap or, sometimes, people give them away just to get rid of them. DC motors up tp 2.5 h.p. are pretty common.
- Ripper70
View Woodknack's profile (online now)
Woodknack
13007 posts in 2983 days
#3 posted 03-05-2018 12:54 AM
Keep all the treadmill electronics, you’ll need them. But it’s fairly simple to figure out.
View waho6o9's profile
waho6o9
8812 posts in 3180 days
#4 posted 03-05-2018 02:24 AM
View Lazyman's profile
Lazyman
4485 posts in 1991 days
#5 posted 03-05-2018 03:22 PM
How big of a motor do you want? PSI sells one specifically designed to retrofit small lathes to variable speed but I think that it is only 1/2 HP.
View Andybb's profile
Andybb
2349 posts in 1207 days
#6 posted 03-05-2018 05:19 PM
If you type “free treadmill” into CL you will usually come up with a few. That’s what I did. Plenty of vids on youtube on how to set them up. Had to swap out the pulley in the headstock with the one from the treadmill. Spent $12 on an RPM meter.
-- Andy - Seattle USA
View Sloboy's profile
Sloboy
6 posts in 820 days
#7 posted 03-05-2018 07:42 PM
Just remember that most of the pulleys on the DC motor have reverse threaded nuts. I did not realize this, but luckily I didn’t pull out the cheater before I figured it out :)
The parts you need to keep are the motor, choke (transformer-looking thing) and the speed control board. To control the speed you connect a rheostat to the blades on the speed control board. I used a standard wall dimmer switch for my project. It was really easy to set up.
Andybb
#8 posted 03-05-2018 07:51 PM
This was the most complete and helpful vid I found. Especially the part about the toggle so that it will start back up at the same speed vs having to reset it each time. Very handy. Here is my build. Went very smoothly.
My challenge was the pulley for the headstock. I didn’t want to mess with the pulley on the motor. Naturally, it was a V groove belt to start with vs the treadmill style flat grooved belt. I took the pulley from the treadmill shaft, used the lathe to turn a wood center to fit the pulley and drilled a 3/4” hole for the shaft but was not happy as it started to wear. Coincidentally, I bought a Laguna 1412 bandsaw last week. When I looked inside, the 3/4” motor pulley was the perfect replacement so I called Laguna and ordered one for $10.
woodworm1962
#9 posted 03-05-2018 08:13 PM
Nice work guys!
View Fresch's profile
Fresch
458 posts in 2524 days
#10 posted 03-05-2018 10:26 PM
If you find a Shopsmith 10er it’s cast iron and all set up with 3step pulley.
Andybb
#11 posted 03-05-2018 11:56 PM
Or, you can find a v-belt pulley that will fit on the treadmill motor. You just don’t need the step pulley with the variable speed motor. Matching them either way will work.
View MalcolmLaurel's profile
MalcolmLaurel
301 posts in 2226 days
#12 posted 03-06-2018 01:38 AM
I did a treadmill motor conversion on a metalworking mill/drill last year. Worked great. I just modified a single pulley to attach to the motor’s original flywheel/pulley.
-- Malcolm Laurel - http://MalcolmLaurel.com
Woodknack
#13 posted 03-06-2018 04:28 AM
Andybb
#14 posted 03-06-2018 04:55 AM
The red wire from the motor is the one you put the toggle in to switch it on and off without having to reset the pot.
View MrRon's profile
MrRon
5810 posts in 3847 days
#15 posted 03-06-2018 07:19 PM
Here is a place that sells treadmill motors. They also have controllers for them. http://www.surpluscenter.com/Electric-Motors/DC-Motors/Special-Purpose-DC-Motors/
