keyless chuck
« back to Woodturning forum
Forum topic by CaptCoan posted 02-27-2018 01:50 PM 631 views 0 times favorited 5 replies Add to Favorites Watch
View CaptCoan's profile
CaptCoan
39 posts in 2616 days
02-27-2018 01:50 PM
I have an older ( 1980ish ) Powermatic lathe, I’m looking for recommendations on a good quality keyless chuck. thanks in advance for your advice.
-- EVERY MAN MAKES HIS OWN WORLD/ THE WORLD IS A BEAUTIFUL PLACE
5 replies so far
View MrRon's profile
MrRon
5812 posts in 3853 days
#1 posted 02-27-2018 05:07 PM
Probably the best keyless chuck is the Albrecht (expensive) Check out this online tool catalog for other chucks and shanks. https://www.mscdirect.com/404?intcmp=404catch
View LeeMills's profile (online now)
LeeMills
691 posts in 1911 days
#2 posted 02-27-2018 06:31 PM
You can spend a lot or fairly little.
Most standard 1/2 drill chucks receive a 1/2 X 20tpi arbor.
A good pair (arbor and keyless chuck) should run about $35 for both sections. Not top of the line but maybe in the Dewalt class which is fine with me.
This is an arbor which is a little expensive compared to some places.
http://www.grizzly.com/products/Drill-Chuck-Arbor-MT2-1-2-x-20/T10082
Grizzly has a wide variety of keyless chucks with various prices and various mounting methods.
Although probably not keyless, if you have a drill press many will have a 2MT for the chuck. For a long time I just popped it out of the drill pressed and into the lathe when needed. But I do not know if your tailstock is 2MT or not.
View TheFridge's profile
TheFridge
10859 posts in 2096 days
#3 posted 02-27-2018 06:57 PM
I didn’t want the grizzly but I got one second hand and still new for free. It’s a solid chuck.
MrUnix
7599 posts in 2809 days
#4 posted 02-27-2018 08:50 PM
I’ve never liked keyless chucks on drill presses or lathes as they tend to slip unless you really ratchet them down tight. For a lathe, where it is being used stationary, you don’t need an uber-precision chuck either. I picked up one of these HF chucks for under $12 to use on both my South Bend and Powermatic PM45, which both have MT2 tapers in the tailstock. I was quite surprised at the quality of the machining given the price. Basically it’s a JT33 1/2” chuck on a MT2 → JT33 adapter, so you can swap out the chuck if desired. Worth the price just for the adapter alone :)
View Madrona's profile
Madrona
123 posts in 1505 days
#5 posted 02-28-2018 07:40 PM
I have an older ( 1980ish ) Powermatic lathe, I m looking for recommendations on a good quality keyless chuck. thanks in advance for your advice.
- CaptCoan
I got this one though I don’t think it was a PSI and I think it was a small amount less than this. It has served me well for about five years. https://www.amazon.com/PSI-Woodworking-Products-TM32KL-Keyless/dp/B004CVJC3E/ref=sr_1_5?ie=UTF8&qid=1519846652&sr=8-5&keywords=1%2F2+keyless+chuck
-- Living In The Woods Of Beautiful Bonney Lake, Washington
