Help
Forum topic by Grubby posted 02-26-2018 01:34 PM 435 views 0 times favorited 7 replies Add to Favorites Watch
View Grubby's profile
Grubby
10 posts in 692 days
02-26-2018 01:34 PM
I am new to woodworking and taking a try at making my son a dresser for his bedroom (the six dresser from Woodsmith). I built the outer shell and the carcass individually and then put them together. However, the carcass is slightly higher/bigger than the outer shell and leaves a gap that you can see when the top is on. What options do I have to fix this? With the gap being somewhat significant and the carcass being made of birch plywood I really do not want to sand or plane all the material away. I was think of adding a trim piece but the 2×2 corners create somewhat of a problem. Any suggestions would be appreciated. Sorry the pictures are rotated.
7 replies so far
View John Smith's profile
John Smith
2128 posts in 764 days
#1 posted 02-26-2018 01:55 PM
a little help with the photos:
-- I am a painter. That's what I do. I paint things --
View ChefHDAN's profile
ChefHDAN
1496 posts in 3451 days
#2 posted 02-26-2018 01:55 PM
Difficult perspective from the close up photos, can you put up a picture of the whole project? Shell and carcass explanation does not quite make sense, some better pics will certainly get you some ideas from the Jocks
ChefHDAN
#3 posted 02-26-2018 01:57 PM
Ah, cool John that helps a bit,
Is that a face frame or a drawer top lifting the top????
Grubby
#4 posted 02-27-2018 12:31 AM
Sorry for the confusion here are some more pictures. Also the inner carcass is slightly higher than the outer shell pushing the table top up
View 000's profile
000
2859 posts in 1501 days
#5 posted 02-27-2018 12:47 AM
Cut the side leg down so that a 3/4” cap could be attached.
Something like this:
View mel52's profile
mel52
1179 posts in 866 days
#6 posted 02-27-2018 03:26 AM
The 3/4 inch cap is a good idea. I would never have thought of it. May need this idea for a future problem. Thanks.
-- MEL, Kansas
woodbutcherbynight
6033 posts in 3010 days
#7 posted 02-27-2018 04:59 AM
Another cool tip to get me out of a jam when I screw up.
