Brad Nail Blowout
Forum topic by IantheTinker posted 01-26-2018 01:55 AM 3888 views 0 times favorited 40 replies Add to Favorites Watch
View IantheTinker's profile
IantheTinker
285 posts in 1095 days
01-26-2018 01:55 AM
Topic tags/keywords: brad nail gun blowout veneer plywood trim
I was installing some trim on a dvd shelf I am working on and I had 2 brad nails go wonky on me and punch through the birch veneer on the plywood. I was careful to line my gun up properly so that the chiseled tip of the nail had plenty of room to veer off, but it still happened. How can I fix this? One of them is not so bad, but the other was quite obvious. I tried pulling the trim away, but the other nails were holding it in place too well and I was afraid of scuffing things up. Any tips are appreciated, thank you.
-- pensivewoodworker.com
40 replies so far
View Ripper70's profile
Ripper70
1379 posts in 1876 days
#1 posted 01-26-2018 02:12 AM
The different densities in the layers of plywood can sometimes cause the nail to take a path of least resistance and veer off course. I’ve had this happen more than once. You can try a couple of things to fix your issue.
Method #1) Do not try to back the nail out of the hole. Rather, pull it through and hope it’s only a minor repair.
Method #2) Grab the end of the nail that’s sticking through the piece and bend it back and forth to break it off. Most times it will break off just below the surface of the wood and the marred surface will have a minor imperfection that can be repaired.
I’ve taken to using glue with trim moldings and 23 gauge pin nails to hold the trim in place while the glue sets. For me, a much better approach, and virtually no need to fill nail holes after the trim is installed.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View John Smith's profile
John Smith
2817 posts in 1130 days
#2 posted 01-26-2018 02:16 AM
if it is a good clean protrusion, I would just cut it off flush and bury it with a nail set
of the same size and mix some wood flour the same color and fill the hole.
the more you tug and pull on it – the worse it will get.
No.1 tool choice would be flush cut end nippers.
No.2 tool choice would be the basic side cutters.
this is a good tool to have in your box if you are going to be doing much brad work.
any set of side cutters can be ground to have a flat flush cutter side and blunt nose
as long as you can put some power in it. . . . also the Dremel Tool with a cut-off wheel will work well.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View Gilley23's profile
Gilley23
489 posts in 1350 days
#3 posted 01-26-2018 02:32 AM
Yeah, sometimes you can’t help it. The end of the nails are chiseled so if your angle is even slightly off and they hit a tougher spot they’ll curve and shoot out somewhere else. Remove and repair.
IantheTinker
#4 posted 01-26-2018 02:47 AM
I ve taken to using glue with trim moldings and 23 gauge pin nails to hold the trim in place while the glue sets. For me, a much better approach, and virtually no need to fill nail holes after the trim is installed.
- Ripper70
I recently saw a video, from Woodworkers Guild of America I think, and the fella in that also used 23 gauge pin nails. They left such tiny holes, I will have to get a pin nailer at some point so that I can switch to them as well. Thanks for the reply!
IantheTinker
#5 posted 01-26-2018 02:47 AM
- John Smith
I think I will give this a try, thank you, John.
View Rich's profile
Rich
6388 posts in 1557 days
#6 posted 01-26-2018 05:20 AM
What gauge? 16, 18, 23?
View Andybb's profile
Andybb
3041 posts in 1571 days
#7 posted 01-26-2018 05:49 AM
The greatest $/usage tool value on the planet. (at least for me) Use it ALL of the time. Mine is 4 yrs old and still cuts brads like butter. Then, like somebody said, tap the end with a nail set and you’re good to go after a dab of putty or glue and sawdust. Plywood is funny like that.
-- Andy - Seattle USA
View Tony_S's profile
Tony_S
1394 posts in 4051 days
#8 posted 01-26-2018 10:40 AM
You mentioned the chiseled tip on the nails, so I assume that you are aware that you need to hold the nail gun perpendicular to the plywood(or molding) edge?
Another mistake I see quite a few people make, is using nails that are too long for the given task. The longer the nail, especially with the lighter gauge 23’s, the more prone they are to curl/veer.
-- “Wise men speak because they have something to say; fools because they have to say something.” – Plato
View AlaskaGuy's profile
AlaskaGuy
6338 posts in 3277 days
#9 posted 01-26-2018 11:03 AM
https://youtu.be/aXIH2c_1PzE
View fivecodys's profile
fivecodys
1718 posts in 2604 days
#10 posted 01-26-2018 04:30 PM
Not only can the brad nail deviate its course and pop out of the board, it can pop right into your finger too!
This is why I keep my fingers well away from what I am shooting a brad nail into.
I agree with the previous comment about using a brad that is longer than needed.
Almost all of my blowouts have happened when I had a longer brad than I really needed but I was either too lazy to stop and change them out or I was using what I had “on-hand”.
I have used a nail set a few times to push the brad back into the wood and then repair the area with sawdust and glue. I have even used a pencil to draw the grain back onto my patch and it is surprising how well it blended in.
-- A bad day woodworking is still better than a good day working.
View Lazyman's profile
Lazyman
6304 posts in 2355 days
#11 posted 01-26-2018 05:02 PM
Another mistake I see quite a few people make, is using nails that are too long for the given task. The longer the nail, especially with the lighter gauge 23 s, the more prone they are to curl/veer.
- Tony_S
+1.
The brads can usually only bend left or right so if you orient the gun properly and don’t nail too close to the end, it is less likely to veer off course and if it does it will still be inside the plywood.
What I have done when I have forgotten this or couldn’t turn the nail gun in the proper orientation was to pull the brad all the way through where it protruded to remove the errant brad. Of course fixing the damaged veneer is another problem.
View 000's profile
000
2859 posts in 1867 days
#12 posted 01-26-2018 05:10 PM
Who has time to go find a hammer and punch to set the nub after you clip it.
I just use the set pin on the nailer, pull the nails back and fire away.
John Smith
#13 posted 01-26-2018 05:56 PM
jbay: “Who has time to go find a hammer and punch to set the nub after you clip it.”
I do – I have the time to do quality work.
My tools are organized and I don’t have to “go find” anything.
View Rich's profile
Rich
#14 posted 01-26-2018 06:48 PM
My tools are organized and I don t have to “go find” anything.
- John Smith
I’ve seen jbay’s portfolio, John. You might do well to rethink that “quality work” crack.
AlaskaGuy
#15 posted 01-26-2018 06:52 PM
- John Smith
I ve seen jbay s portfolio, John. You might do well to rethink that “quality work” snip.
- Rich
Yes you have to give jaybay that, he does very nice work. You should take the time to look at he stuff.
showing 1 through 15 of 40 replies
