Here is an idea to help those in small shops to dry parts after finishing
Forum topic by Holbs posted 01-10-2018 02:38 PM 1485 views 0 times favorited 8 replies Add to Favorites Watch
View Holbs's profile
Holbs
2258 posts in 2632 days
01-10-2018 02:38 PM
Being in a 2 car garage, real estate is a premium. I have fretted how to dry parts after HVLP or by hand as I wanted to spray the entire part (up, down, sides) at once then dry. I do not have room for a dedicated horizontal shelf drying rack, is the big problem. Considered hanging from the ceiling or some other means. Until I came across this at a local auction: a portable clothesline stand that can be quickly broken down into a simple box when not in use. I also used J hooks and 30lb fishing line to suspend my parts. It works. I have 8 plantation shutter frames & slats hanging off of it. I would feel comfortable adding 8 more.
I know laying items horizontally to let gravity have it’s affect is optimal… maybe if I had more real estate. This should be considered as a possible alternative.
8 replies so far
View Carloz's profile
Carloz
1147 posts in 1194 days
#1 posted 01-10-2018 02:43 PM
If going this way you do not need the drying rack. A clothesline hung between two adjacent ( in the corner) or opposite walls would arguably do the same taking no room at all when not in use.
Holbs
#2 posted 01-10-2018 02:46 PM
I like that idea, Carloz. Probably would be better than this rack. But I have 20’ x 20’ between walls and no corners to spare so in my situation, this breakdown rack works great.
View Gene Howe's profile
Gene Howe
11995 posts in 4031 days
#3 posted 01-10-2018 02:58 PM
Great idea, Holbs. Thanks.
117905 posts in 4180 days
#4 posted 01-10-2018 03:31 PM
Ingenious idea , thanks for the tip.
View LesB's profile
LesB
2303 posts in 4046 days
#5 posted 01-10-2018 06:43 PM
I like the idea of the old clothes line umbrella.
A single clothes line will work but there will be some sag in the line so figure out how to keep things from sliding towards the center. I occasionally to a similar thing with 1×2 boards suspended from the ceiling or between benches; no sag unless the items are really heavy.
-- Les B, Oregon
View Tony1212's profile
Tony1212
375 posts in 2337 days
#6 posted 01-11-2018 03:47 PM
Wow! Ever had something just trigger a flood of memories?
This post brought back tons of memories of my grandfather’s shop. He had a rope strung from one side to the other with clothes pins all along it. He would drive a finishing nail into a unseen area of the project, paint it and then hang it like laundry from the rope clamping the clothes pins on the nail.
He also had a calendar with a pin-up model at the top. Her clothes were painted on a clear plastic sheet that you could lift up to see her naked. We always figured he kept it hidden so us grandkids couldn’t find it. Getting closer to that age myself, it was probably so that grandma couldn’t find it.
Thanks for the memories.
-- Tony, SW Chicago Suburbs
View BurlyBob's profile
BurlyBob
6895 posts in 2868 days
#7 posted 01-11-2018 06:22 PM
Now that is a great idea and amusingly simple. Way to go.
Holbs
#8 posted 01-12-2018 03:34 AM
Yep..this works nicely for my needs. The big reason to share this possible alternative is that it easily breaks down into the box in 20 seconds, and yet expands to a large hanging area in the same amount of time. It currently has vinyl (or maybe rubber) clothes line that is smooth so the hooks I made from jack chain slide around under force. I’ll eventually swap the line out to rope with knots or such.
