Assistance with purchasing Corner Pieces
Forum topic by JulianBronxNY posted 12-21-2017 12:53 PM 541 views 0 times favorited 10 replies Add to Favorites Watch
View JulianBronxNY's profile
JulianBronxNY
2 posts in 769 days
12-21-2017 12:53 PM
Hi All,
I am trying to build a wood box. It will measure W24” x H37” x D 16”
I would like to have my corners rounded.(Not sure the radius yet)
I don’t have the tools to make this happen. Does anyone know where I can find someone that sells something like this?
Thank You guys…. this is my first post.
10 replies so far
View cabmaker's profile
cabmaker
1745 posts in 3420 days
#1 posted 12-21-2017 03:19 PM
I don’t normally spend much time on posts with limited information…...but
Are you looking for corner protective/design overlays ?
You can get corner pcs in brass,etc that simply install after the box is completed
There are many, many types and styles
OR….are you talking about rounded corner pcs in hardwood ? if so…those are available as well…..just know that with this type your box will need to be a design that will accept these premilled inlays.
Actually, your post suggests that you don’t have a clear understanding of what is needed for your project…..and if you do….reach down real deep and try to explain why your doing and what/why something additional is needed.
Smitty_Cabinetshop
16350 posts in 3230 days
#2 posted 12-21-2017 03:26 PM
Is it a shop box or fine furniture? Rounded corners can be made with a ROS, or block planes, or router bits. Probably a few other ways, too.
Maybe a pic of what it is you’re trying to build? As in, a pic of an inspiration piece? That’d help get answers.
View 000's profile
000
2859 posts in 1510 days
#3 posted 12-21-2017 03:30 PM
Look thru the millwork components
http://www.aitwood.com/default.asp
View John Smith's profile (online now)
John Smith
2139 posts in 774 days
#4 posted 12-21-2017 03:30 PM
X2 = I don’t normally spend much time on posts with such limited information……but….
I have read and re-read the original post a dozen times. suffering from ADHD, dyslexia, CRS,
and a host of other mental and physical ailments, I don’t know if he is asking where he can
purchase the tools to make the box, embellishments to make round corners or someone that
can actually make that type of custom box and ship it to him …...
hopefully he will come back with a more precise idea of what he is asking for.
-- I am a painter. That's what I do. I paint things --
Smitty_Cabinetshop
#5 posted 12-21-2017 04:15 PM
Edit: The original poster is not asking how to make the box – he is asking where to buy one already made. he said: Does anyone know where I can find someone that sells something like this?
- John Smith
How are we to interpret: “I am trying to build a wood box”? Keep in mind we’re usually in it to make stuff, and not a clearinghouse for vendors selling wooden boxes. Suggesting the ‘how’ is what we do!
John Smith
#6 posted 12-21-2017 04:19 PM
build a box from materials he already has on hand maybe ?
hopefully he will come back with some clarification.
it’s time for my meds now
JulianBronxNY
2 posts in 769 days
#7 posted 12-21-2017 04:42 PM
Hi All,
I really appreciate all the feedback and also request for further clarification. As I did more research I realized that I can actually build my box using quarter Round Molding on the ends of my box. I think I figured out what I need to actually build it myself. Just FYI I am building a box for a Photo Booth business. The ones sold online are way to expensive for me.
Again thank you guys and Happy Holidays.
John Smith
#8 posted 12-21-2017 05:12 PM
Julian – now that we have a better understanding of what you are asking,
yes, building the common box with 1/4 round outside edges is quite doable and will
look good…... the inside bracing can be square or triangle – whatever you can find
at your Big Box Store. glue, screws and small brads will suffice to keep it all together.
if you are going to paint it after fabrication, you can use Bondo to fill any imperfections first
to give it that finished and professional look.
I am imagining this to be a seat to sit on in your photo booth ??
View BobAnderton's profile
BobAnderton
309 posts in 3402 days
#9 posted 12-24-2017 11:21 PM
I’ll mention roundover router bits, an example of which is here. The bearing on the end of the bit rides along the side of your assembled box and the bit creates a radiused edge from what was a sharp corner.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View HerbC's profile
HerbC
1801 posts in 3471 days
#10 posted 12-24-2017 11:55 PM
I ll mention roundover router bits, an example of which is here. The bearing on the end of the bit rides along the side of your assembled box and the bit creates a radiused edge from what was a sharp corner.
- BobAnderton
CAUTION!!!
If you use a router roundover bit to round the corners of the assembled box, you MUST ensure that there are no metal fastners, such as nails or screws, in the wood edges you will be routing. Failure to follow this safety step can lead to damage to the project, damage to the router or bit, and injury to the user of the router…
Good luck!
Be Careful!!!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
