Deposit buildup on my hand plane
« back to Hand Tools forum
Forum topic by SpottedGum posted 12-18-2017 07:16 AM 1570 views 0 times favorited 8 replies Add to Favorites Watch
View SpottedGum's profile
SpottedGum
13 posts in 1382 days
12-18-2017 07:16 AM
Topic tags/keywords: joining finishing milling
Why does my hand plane build up with hard deposits on the under side when planing. I’m planing I think Blackbutt hardwood and it is hard but I get these small deposits both before and after the blade which then lift the blade off the surface of timber I’m planing. Most annoying and happens within 2 or 3 passes of the plan.
Should I wax the underside of my plan?
8 replies so far
View Don W's profile
Don W
19420 posts in 3170 days
#1 posted 12-18-2017 12:14 PM
I don’t know what blackbutt hardwood is but I do know you should wax the sole. Try it, you’ll be amazed at the difference it makes.
View AESamuel's profile
AESamuel
100 posts in 1825 days
#2 posted 12-18-2017 12:56 PM
Do you have any close pictures of the wood and the deposits? It almost sounds like a resin, sap, or gum buildup from the wood.
View bondogaposis's profile
bondogaposis
5604 posts in 2953 days
#3 posted 12-18-2017 01:14 PM
Wax the sole, definitely.
-- Bondo Gaposis
View Tim's profile
Tim
3859 posts in 2563 days
#4 posted 12-18-2017 03:11 PM
This site mentions the “extractives” in the wood may be a problem for finishes, and that could be what’s going on. I assume they are referring to some kind of resin also. If waxing the sole doesn’t work, try a light machine oil on a rag, and if that doesn’t work, if you have a scrap to test on, try wiping the wood with mineral spirits (maybe called white spirit down under too?) or other solvent.
View Robert's profile
Robert
3598 posts in 2083 days
#5 posted 12-18-2017 05:00 PM
Resinous wood can do this.
View Manitario's profile
Manitario
2794 posts in 3485 days
#6 posted 12-18-2017 05:16 PM
It’s resin, I get the same when I plane wenge or African Blackwood. As others suggested, regular waxing the sole will help.
SpottedGum
#7 posted 12-23-2017 08:08 AM
Wax works excellent. Thanks.
View robscastle's profile
robscastle
6675 posts in 2806 days
#8 posted 12-23-2017 09:30 AM
Spotted Gum ! just had to be an Auzzie !!
Yeah mate post a coupla pictures so we can see whats going on and while your at it a few sheillas too!! they never go a stray!
-- Regards Rob
