OUCH what did I do Wrong?
Forum topic by Dautterguy posted 03-02-2008 04:38 PM 1380 views 0 times favorited 16 replies Add to Favorites Watch
View Dautterguy's profile
Dautterguy
51 posts in 4297 days
03-02-2008 04:38 PM
While cutting some 1x poplar yesterday, I was using a push stick on the fence side, somehow the small fall off was caught by the saw blade and of course the “MISSLE” found my stomach. I was wearing a tool belt which took the blunt force. This happened twice, The first time it was a piece about 1×2x6 the second it was 1×4x6. For the like of me I cannot figure out what I was doing wrong. Any help would be apprecated as I am tired of being black and blue
16 replies so far
View GaryK's profile
GaryK
10262 posts in 4524 days
#1 posted 03-02-2008 04:42 PM
Did you have the blade “just above” the height of the wood you were cutting?
View gizmodyne's profile
gizmodyne
1784 posts in 4626 days
#2 posted 03-02-2008 04:43 PM
Start by checking the alignment of fence, blade, etc.
How long are the pieces?
-- -John "Do I have to keep typing a smiley? Just assume it's a joke."
Dautterguy
#3 posted 03-02-2008 04:45 PM
Sorry I faled to mention . The blade height gullet high. Just peeking over the height of the wood.
GaryK
#4 posted 03-02-2008 05:02 PM
Start with what Gizmo suggested.
I like to raise the blade by about 1” higher than the wood. I feel that it less likely for the back side of the blade to pick up the piece and throw it back.
I wouldn’t think that fence alignment would be that much of an issue since it’s your fall off that’s
getting kicked back.
You could also try two push sticks.
View Mark E.'s profile
Mark E.
387 posts in 4278 days
#5 posted 03-02-2008 05:07 PM
It could just be that the kerf is closing up behind the blade due to internal stresses in the wood.
Are you using a splitter/riving knife behind the blade?
-- Mark
Dautterguy
#6 posted 03-02-2008 05:08 PM
Thank You, At this point I am willing to try anything, I just cannot figure this one out. First time the fall off got me.
16284 posts in 4754 days
#7 posted 03-02-2008 05:17 PM
You give approximate dimensions of your cutoff, but which dimension is parallel to the blade? What I’m getting at is, is your cutoff small enough to fall partially between the blade and the table? This causes the effect youare describing, and is prevented by using a zero-clearance insert.
View Peter Oxley's profile
Peter Oxley
1426 posts in 4410 days
#8 posted 03-02-2008 05:17 PM
This is kind-of a wild guess, but is there any chance your throat plate is lower than the table surface? With a short piece like you are cutting, if one edge was on the table surface and the other edge dropped onto a slightly lower throat-plate it would tip the drop toward the blade.
Taking the same theory one step farther, a zero clearance throat plate might help, and would probably be a good idea with pieces as short as you are cutting.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
27250 posts in 4358 days
#9 posted 03-02-2008 05:39 PM
I agree wit Charlie and Peter’s assessment about the zero clearance insert. These are readily made or available commercially ($20). The only time I use my standard plate is when I am doing bevel operations.
Dick, & Barb Cain
8693 posts in 4835 days
#10 posted 03-02-2008 06:57 PM
Back in the dark ages in 1947, when I first used a table saw, my instructor said run your saw blade about 1/8”
above the stock thickness you’re cutting. When I watch wood working shows, I never see this.
Also on a band saw, I always lower my guide down just above the wood. I kind of shudder when I see the experts
on TV, doing just the opposite. I think that’s why there’s a lot of bandsaw accidents.
View USCJeff's profile
USCJeff
1065 posts in 4604 days
#11 posted 03-02-2008 07:02 PM
All good suggestions. I’d add a few more possible issues. It’s possible that the vibration from the saw makes the cutoff walk back to the blade. It could also be the wood itself. Changes in feed rate and the boards density could cause the board to “twist” as the blade cuts the last bit. The kerf closing as mentioned could do this too. Is there much runout with your blade? The blade wobbling (even slightly I would think) at high speeds could catch the cutoff.
Another solution is to use a sled of some sorts. A sled or long miter fence will push both pieces past the blade. They have their limitations though. Good luck. Stay safe.
-- Jeff, South Carolina
View Myron Wooley's profile
Myron Wooley
226 posts in 4432 days
#12 posted 03-02-2008 07:37 PM
Weird. I’ve never seen the offcut from a rip come back, but my son had a kickback that sounds similar. He was using the rip fence incorrectly to make a crosscut. He allowed his left hand to follow the offcut, and when the cut was complete, the back of the blade caught the piece between the fence and the blade and it went zinging back into his stomach. No hand injuries, but he was bruised pretty good. The board was only 1/4” thick.
Some questions to ponder:
In your case, was this a really a rip or should it have been treated as a crosscut?
Were you crosscutting using the rip fence?
Where was your left hand?
Were you making a crosscut with the miter gauge, using the fence as a stop, and pushing the offcut?
Did the offending piece come from the left or right side of the blade? Your description doesn’t say.
In order to generate the kind of force you experienced, the blade needs to work in conjunction with a fulcrum. Usually it’s the fence, but if the table insert is too low or the slot overly wide, it could catch. The dimensions you gave seem too large for this scenario, though.
Could you take some pics of the setup at the moment of the kickback? (please don’t turn on the saw!) Maybe we could get a better idea of what went wrong, and we can all benefit.
I’m glad you weren’t seriously injured.
-- The days are long and the years are short...
View Josh's profile
Josh
119 posts in 4474 days
#13 posted 03-02-2008 09:31 PM
Kick backs scare me. I watched a guy in high school take one to the dome and that left an impression.
I read that the blade is safest when it is just peaking over the piece you are cutting. I was wondering if the saw blade is more accurate the further it is raised?
I also try not to stand behind my cut. If you are getting hit in the stomac are you standing in the right spot when you are cutting? Should he of been standing further to the side when making this cut?
Dautterguy
#14 posted 03-03-2008 05:50 AM
Thank You All for the responses. I have been reading all of the posts everymorning. The responses were overwhelming.
View dlgWoodWork's profile
dlgWoodWork
160 posts in 4290 days
#15 posted 03-03-2008 06:10 AM
A lot of good responses have been mentioned already. I will add one more. You have your cutoffs listed as either 4 or 6 inches long. That is a pretty short piece of wood to try to be ripping, if that is what you are doing. I know from experience. I was ripping a piece of maple about 6 inches long once, once the end of the cut was made, the back of the piece climbed on top of the blade, then the blade threw it off my chin. Make sure if you are ripping stock, that the piece is long enough to pass the back of the blade when the cut is complete.
-- Check out my projects and videos http://dlgwoodwork.com
