Refinishing dresser and armoire
Forum topic by Danette Smith posted 02-26-2008 06:32 PM 1019 views 0 times favorited 3 replies Add to Favorites Watch
View Danette Smith's profile
Danette Smith
161 posts in 4788 days
02-26-2008 06:32 PM
Topic tags/keywords: walnut oak
My husband is cutting our dresser and armoire to a smaller size to fit into our bedroom. The dresser was 8 ft 2 inches and 500 pounds heavy. He has it down to size now…56 inches wide.
He has sanded it down, put a liquid sand paper on it..sanded it more…and now has 2 coats of Rez on it. We plan to paint it a white enamel.
Question: Is there a specific enamel we should use? How many coats to use? Sand in between coats?
Question: What would you recommend to seal the enamel? Varnish? Polyurethane?
I’m posting pics of it under projects…Danette Smith
Thank you…Danette
-- Danette Smiths Pyrography and Easels - http://www.danettesmithpyro.weebly.com
3 replies so far
View Al Killian's profile
Al Killian
273 posts in 4261 days
#1 posted 02-27-2008 02:34 AM
After useing a liquid stripper, you should wash the wood down with a minerail spirits. This be desolve any remaing chemicals. A good coat of primer will help give a nice smooth finish. For painy a good latex arclick will hold up to the abuse the dresser will see. There is no need to sand between coats of paint.
-- Owner of custom millwork shop
Danette Smith
#2 posted 02-27-2008 08:43 AM
Hi Al!
Thanks for answering my questions. Do I need to put some sort of sealant on it after painting it? If so, what do you recommend? Thank you…Danette
Al Killian
#3 posted 03-02-2008 09:19 PM
No sealer just a good primer would be fine. I pearsonaly use shirwin& williams(sp) paint. It is higher priced, but give a nice finish. Just let the pain sit a few days before you move it into the the house. This will guve it time to cure.
