Old Powermatic lifting and 3 phase converting advice?
Forum topic by PatrickIrish posted 04-17-2017 02:37 AM 905 views 0 times favorited 4 replies Add to Favorites Watch
View PatrickIrish's profile
PatrickIrish
153 posts in 2650 days
04-17-2017 02:37 AM
I recently won an auction for an older powermatic 160 planer. A 1200lb beast. It has a 3 phase 5hp motor.
Questions I have:
Best way to power this via my 220 single phase? I think a rotary phase converter is the best route but I think it has to be a 10hp to properly work. I could source a 5hp single phase, would that work?
How do I run straps correctly around it to lift it off a pallet with a forklift in order to set it back down on a steel frame with casters I’m gonna make? I don’t want to run straps around the piece and bend something.
PatrickIrish
#1 posted 04-17-2017 02:39 AM
View MrUnix's profile
MrUnix
7582 posts in 2803 days
#2 posted 04-17-2017 02:45 AM
What is the FLA of the motor? Most likely, you can use something like this TECO (westinghouse) VFD – for about $200. Another option would be to go with a static phase converter, but you will reduce the horesepower a bit going that route. An RPC is overkill if you only have the one machine, and is kind of a PITA in that situation.
View TungOil's profile (online now)
TungOil
1371 posts in 1099 days
#3 posted 04-17-2017 03:35 AM
For lifting guidance, I would suggest calling PM directly. I find their tech service guys to be knowledgable and helpful.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
MrUnix
#4 posted 04-17-2017 03:55 AM
Forgot about the lifting part!
You may find some useful information over at the OWWM site, such as this thread:
PM160 removal (from truck bed) ? Pics added
Asking Powermatic isn’t a bad idea either :)
