need help! best workbench finish? oil base paint, latex, or stain and poly?
Forum topic by drm11981 posted 04-09-2017 08:19 PM 2913 views 0 times favorited 2 replies Add to Favorites Watch
View drm11981's profile
drm11981
7 posts in 1187 days
04-09-2017 08:19 PM
Topic tags/keywords: bench oil base latex durable help
Hey all! I am at the point of pure confusion…There is so many different ways to go for finishing. I am at the point of my workbench/assembly table build where I need to put a finish on it. I want the MDF drawer fronts to have a high shine to them, in like a Safety Blue color. So there i was planning Rustoleum Pro. with hardener air sprayed. The main frame and insides mostly pine I want black with a high shine also Rustoleum. Is Rustoleum with hardener a good durable choice? I will prime it all with zissner coverstain primer since i just got 2 gals for 5$ dented cans lol. I have alot of time into this massive bench and want the finish that will hold up to being brushed down often, and being hit with some occasional sparks. If anybody has better options please list them. I’d truly appreciate some help!
thanks!
2 replies so far
View JayCee123's profile
JayCee123
200 posts in 1539 days
#1 posted 04-10-2017 08:18 PM
On my wood tops and MDF tops I use a wipe on oil/poly. I’m not sure where the sparks are coming from? Grinder possibly? As I wear the tops, should they need help, a simple wipe over makes them look pretty good for work tops.
View LDO2802's profile
LDO2802
167 posts in 1205 days
#2 posted 04-10-2017 08:41 PM
I like the natural wood of my benchtop. I use tung oil on it so I don’t have to do a lot of maintenance to it. Its made to be worn out, not pretty in my use.
