Fan/switch for 220 Air compressor
Forum topic by elevatedwoodworks posted 03-24-2017 01:55 PM 632 views 0 times favorited 2 replies Add to Favorites Watch
View elevatedwoodworks's profile
elevatedwoodworks
4 posts in 2116 days
03-24-2017 01:55 PM
Hi,
Does anyone know the answer for making a 110v fan come on when my 220v air compressor kicks on?
I know there are the vacuum ones, but that is 110 through out.
2 replies so far
View Bill1974's profile
Bill1974
185 posts in 4442 days
#1 posted 03-24-2017 05:10 PM
your best bet is to use a contactor to do that job. Should be a cheap $10 part. Just look for a contact with the a 220 VAC coil and run it in parallel with the compressor motor. Don’t worry about power it’s only a few watts.
View TheFridge's profile
TheFridge
10863 posts in 2943 days
#2 posted 03-24-2017 05:25 PM
i know what he ^ says will work. I don’t know offhand if that is the way to go or not.
Contactor or relay (if appropriately sized in HP) controlled by a current switch. Current switches are used for this application all the time.
