Forum topic by Dagobah | posted 03-15-2017 12:15 AM | 1784 views | 0 times favorited | 11 replies | ![]() |
I’ve seen plenty of videos about filling knots with epoxy, but haven’t seen anything addressing when to fill. Is it always necessary? I’m building a couple floating shelves for our kitchen. One of the boards has a knot with a crack partially through. Do I risk the board being unstable if I don’t fill the knot, or is it something I really need to worry about? It’s just a shelf after all. |
11 replies so far
#1 posted 03-15-2017 12:23 AM |
Pine has knots & sap. If you’re not going to plane it should be ok. M -- The hump with the stump and the pump! |
#2 posted 03-15-2017 12:25 AM |
This is a 1.5” thick piece of walnut. I’ve already planed and sanded, ready for finish. Just now realized I should double check leaving the crack before I went any further. |
#3 posted 03-15-2017 12:28 AM |
The knot in question: |
#4 posted 03-15-2017 12:38 AM |
It’s your choice. If it is going to be exposed might leave it alone or fill it with a colored epoxy to draw attention to it your choice. The only time you really need to glue or epoxy a know is if it is loose. -- Bruce, Boise, ID |
#5 posted 03-15-2017 12:43 AM |
Walnut is a very stable wood. Should be ok unless subjected to extremes of humidity and temperature. That is a beautiful piece of wood! I’m not sure of scale/size from the picture, but have you considered a small butterfly of a complementary wood. Might look nice. -- Dave Smith - If our phones fall, we panic. If our friends fall, we laugh. |
#6 posted 03-15-2017 01:31 AM |
I leave all knots as they are, just natural character. |
#7 posted 03-15-2017 02:03 AM |
I would advise against using a dutchman in a knot. you could be left with a mess in a hurry. I mix up copper powder and walnut sawdust to fill my walnut cracks and knots. |
#8 posted 03-15-2017 02:47 AM |
I fill cracks in black walnut knots with epoxy mixed with lamp black. -- Roger M, Aiken, SC |
#9 posted 03-15-2017 02:53 AM |
It wouldn’t take that long to fill it with epox and sand. I fill all cracks with epoxy before milling. -- I always knew gun nuts where afraid of something, just never thought popcorn was on the list. |
#10 posted 03-15-2017 05:10 PM |
For me, it depends on whether the crack is confined to the knot. In other words, could you remove the knot with a chisel cleanly and if so, would the crack be gone? If not, I like to fill the crack to try to prevent further checking. -- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA |
#11 posted 03-15-2017 05:24 PM |
This is what I did on a walnut box. I saved sawdust from my cuts and mixed it with TB-3 and used it as a filler. Since the sawdust was from this piece of wood, it worked out well. While it did not end up perfectly smooth, it did/does take the emphasis off of the crack and it blends well. Just my 2-cents worth… -- HorizontalMike -- "Woodpeckers understand..." |
Forum | Topics |
Woodworking Skill Share
13240 |
Woodturning
2829 |
Woodcarving
578 |
Scrollsawing
417 |
Joinery
1913 |
Finishing
6395 |
7940 |
32937 |
CNC Woodworking
334 |
Hand Tools
6487 |
Jigs & Fixtures
1824 |
Wood & Lumber
7308 |
1647 |
Focus on the Workspace
2644 |
1273 |
Woodworking Trade & Swap
5436 |
LumberJocks.com Site Feedback
2401 |
Coffee Lounge
9685 |
