Table saw blade won't go back to 90 degrees
Forum topic by MikeDe posted 02-18-2017 07:18 PM 5983 views 0 times favorited 7 replies Add to Favorites Watch
View MikeDe's profile
MikeDe
56 posts in 3608 days
02-18-2017 07:18 PM
I am having trouble getting the blade back
to 90 degrees on my Delta Table Saw after
tilting the blade for an angle cut.
When I get close to 90 the wheel gets hard
to turn, and it seems to have something, like
saw dust in the way that will not let it
come to a stop.
7 replies so far
View cutmantom's profile
cutmantom
407 posts in 3952 days
#1 posted 02-18-2017 07:34 PM
Definitely check for sawdust buildup or a stray piece of wood offcut, is the bevel still clamp released, it might tighten up as you turn the hand wheel, also is the 90 degree stop secure or has it move due to vibration
Just my 2cents
View waho6o9's profile
waho6o9
8953 posts in 3494 days
#2 posted 02-18-2017 07:37 PM
Unplug it and clean out the insides.
View alittleoff's profile
alittleoff
548 posts in 2193 days
#3 posted 02-18-2017 08:20 PM
If cleaning don’t work, check the bolt that stops the blade. It will be located at the end of travel, you can’t miss it.
Gerald
View WhyMe's profile
WhyMe
1322 posts in 2478 days
#4 posted 02-18-2017 08:36 PM
This may sound like a Duh thing but make sure the lock knob is not tightening as you spin the crank.
View BurlyBob's profile
BurlyBob
8021 posts in 3182 days
#5 posted 02-18-2017 09:15 PM
I had the same problem with my Delta x5. Cleaning definitely helped moving the blade but like Gerald said adjusting that bolt at the end of the travel was the game changer.
View ChrisPall's profile
ChrisPall
1 post in 1232 days
#6 posted 07-16-2017 11:48 AM
Good morning! Did anything work?
woodbutcherbynight
6633 posts in 3326 days
#7 posted 07-16-2017 01:41 PM
Had same problem recently, cleaned out the chamber with the blade and found sawdust compacted on top of the stop . Works great now, added checking this to my monthly routine.
