Finishing Logs
Forum topic by Heatherjen posted 02-13-2017 09:22 PM 658 views 0 times favorited 8 replies Add to Favorites Watch
View Heatherjen's profile
Heatherjen
4 posts in 1444 days
02-13-2017 09:22 PM
Topic tags/keywords: log furniture
Hello All…
I’m new here… And an amateur builder… I’ve been working on a few projects this winter and need advice.
I built this little side table yesterday all from trees in my back yard. I was going for the rustic look because I live in a cabin in the woods.
The table is finally ready for sanding and stain.
I’ve decided I like the look of the logs in their natural dark weathered state so I won’t be sanding them. However I did wonder if I should seal them somehow. Because they are so dark it might give the logs some shine? Hence it might bring out the unique characteristics of the logs?
I need opinions.
The logs are also incorporated in the table top so when I finishe the top somehow the table top logs will also be treated.
So… I’m looking for opinions on how to finish the table all together.
I don’t know a thing about finishes and would appreciate any suggestions or advice.
I can’t tell you what kind of wood it is… It was dead standing among birch, aspen, and something tall and thorny. Lol I just liked the wood so I nabbed it.
Keep in mind this is a newbie builder and I really don’t have a clue what I’m doing. I just make it up as I go along. I have few tools and my favorite Leatherman that I get by with.
Thanks for the input!
Warm Smiles, Heather
8 replies so far
View bobasaurus's profile
bobasaurus
3711 posts in 4161 days
#1 posted 02-13-2017 10:22 PM
Some rattle can spray lacquer might work well, easier than trying to wipe or brush something onto every weird part of the logs.
I’d be a little worried about wood movement on that table top… it might crack and split later on in the current configuration, though this would add to the rustic look.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
Heatherjen
#2 posted 02-13-2017 10:27 PM
Thanks for the reply. Since I’m so new to wood working can you explain ” wood configuration ” ???
View TungOil's profile
TungOil
1383 posts in 1472 days
#3 posted 02-14-2017 12:38 AM
Very interesting build, I like it.
What Allen is saying is that the grain direction on your mitered frame runs perpendicular to the grain of the top. since wood moves across its width with moisture changes significantly more than its length, these parts will fight each other. eventually either your miters will open up or the top might get some splits.
For finish, I agree spraying would be easiest way to cover the irregularities. Lacquer or polyurethane would work well.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View canadianchips's profile
canadianchips
2632 posts in 3974 days
#4 posted 02-14-2017 02:33 AM
Hello.
Polyurethane and Varathane tend to turn wood a yellow finish. The more coats the yellower it will go.
I use product from MINWAX called Polycrylic SATIN finish. Your wood will retain its original color. After time this product will harden to almost plastic finish.
MY choices….others mat have their own preference
Have Fun !
View PineSucks's profile
PineSucks
283 posts in 2004 days
#5 posted 02-14-2017 09:55 PM
I have had good results using Helmsman spar urethane in the rattle cans. Read instructions, follow instructions, enjoy your table. You can find it at Home Depot for about 10 bucks a can. Looks like you would probably need about 2 cans.
You will also want to get some 220 grit, 320 and 400 grit sandpaper with a sanding block for sanding between coats (covered in the instructions on the can). Dont just use your hand, get the block; it will show you where your hi/lo spots are. Once you’ve found the low spots, that’s wjere you can use the sandpaper without the block.
Oh, and get a bit of tack cloth – also in the paint aisle at depot – so that when you sand, you can remove all the white dust you’ll generate.
Cool first project!
Heatherjen
#6 posted 02-14-2017 10:58 PM
Wow… Thanks for all the great input!!!
I’m not feeling so intimidated to finish it now.
This looks like a great place to hang out and learn.
And thank you for the compliments as well… I just enjoying working with the wood. Kind of addicting!!
Warm Smiles,
Heather
View Kelly's profile
Kelly
3299 posts in 3921 days
#7 posted 02-14-2017 11:10 PM
To clarify, Minwax, Varithane and any other linseed oil based finishes will give the wood an amber look. I like it, but that may be because I grew up with Chevy’s/Fords (polymerized linseed oil and resin mix), but would be partial to Hondas or Subarus (waterborne) if that is what I was most familiar with.
It’s said the polymerized oils hold up to abuse better, but that may not be an issue for you, in this application.
Whatever you do, seal all twenty-seven sides (or six, or whatever) to minimize how fast the wood loses or gains moisture. If the wood was assembled at, say, a fifteen percent moisture content, then moved into a room with a dehumidifier (e.g., fireplace or stove), it’s going to dry and shrink, so it’ll move in strange ways.
All that aside, nice job. I like it too.
View ArtMann's profile
ArtMann
1483 posts in 1793 days
#8 posted 02-16-2017 12:45 AM
I make carved signs and plaques out of barn wood, which reminds me a lot of your table. The wood has been out in the weather for a hundred years and has taken on a lot of dirt, bug residue, etc. I don’t want to lose the barn wood appearance but I need to seal the material before it is hung on someone’s wall. I use rattle can spray lacquer made by Minwax and sold at Walmart, Home Depot and similar places. I would not brush it on if I wanted to keep as much of the original appearance as possible. If the coat is light, it doesn’t alter the color much. I think it is an enhancement of the appearance. You can keep applying light coats until you are satisfied with the appearance. I have used the Polycrylic material that someone else recommended and I think it looks like the surface is plastic coated. Different opinions from different people. If I were you, I would buy cans of all the suggested material and try them on scrap. That table is way too beautiful and unique for you to be unhappy with the finish. This is how the lacquered material on the barn wood looks.
