Your thoughts on a new (cheap) sliding miter saw
Forum topic by JCamp posted 02-07-2017 12:32 AM 1755 views 0 times favorited 23 replies Add to Favorites Watch
View JCamp's profile
JCamp
1243 posts in 1465 days
02-07-2017 12:32 AM
Topic tags/keywords: miter saw
I’ve got an old 10inch delta miter saw. It’s served me well for 15 or 20 years but it was very much a cheapy when it was bought new. Im getting tired of it not doing a full cut on much past a 6 inch board. I would love a Ridgid or hitachi but I simply don’t use one enough to justify spending the money on it. I received an email today that harbor freight had their 12 inch sliding miter saw on sale for 135$ (plus whatever shipping would b) and I also found a different 10inch off brand one that Sears and rural king sells. Sears will ship to the house for free and I hav a some sears rewards points I could use
Anyone hav any experience with either of these or hav any other saws I should consider? Not many these on Craigslist an anywhere close to me.
-- Whatsoever thy hand findeth to do, do it with all thy might
23 replies so far
JCamp
#1 posted 02-07-2017 12:33 AM
View Woodknack's profile
Woodknack
13521 posts in 3294 days
#2 posted 02-07-2017 12:59 AM
I looked at them in person last year and thought they were too rickety, too sloppy when you grab and wiggle them. A 12” non slider will do what you want and take up less space. Just a thought.
View bigblockyeti's profile
bigblockyeti
6837 posts in 2635 days
#3 posted 02-07-2017 01:30 AM
I’ve had hands on the HF saw just to see what you’re getting for your money, while the specs of the saw are impressive the execution and quality overall just aren’t there. I’ll second what Rick stated, a 12” non-sliding saw would be the way to go based on what’s bugging you with your current saw. They’re cheaper and have fewer moving parts to wear than a slider and much lighter if you find yourself needing to move it around.
View ralbuck's profile
ralbuck
6607 posts in 3181 days
#4 posted 02-07-2017 01:40 AM
My son has the Hitachi and it is terrific; I am sure it was very spendy though. I know he has had it form many years too.
-- Wood rescue is good for the environment and me! just rjR
View mrg's profile
mrg
872 posts in 3914 days
#5 posted 02-07-2017 03:59 AM
Hitachi sliders are good saws. They are less than there competitors. Look up the reviews.
-- mrg
View HokieKen's profile
HokieKen
15319 posts in 2053 days
#6 posted 02-07-2017 02:52 PM
I had the HF one years ago. Slide is rough and everything is WAY too sloppy to give any kind of precision at all. I bought it to redo the trim in a house. Before all was said and done, the HF saw was in the shed and I had learned to cope all my trim.
I have a Hitachi 10” non-slider now. It’s a great saw. I’d lean towards a 12” non-slider if you’re looking to stay in the lower price range. A cheap slider will be nothing but a headache.
-- Kenny, SW VA, Go Hokies!!!
View RobS888's profile
RobS888
2829 posts in 2759 days
#7 posted 02-07-2017 03:26 PM
I have the sears compact sliding miter saw. Only thing I don’t like is the hold down, but size, performance and dust collection are very good. It slides forward on rails instead of back so it takes up less space and can be put against a wall.
http://www.sears.com/craftsman-cm-10-in-compact-slide-miter-saw/p-00940753000P
-- I always knew gun nuts where afraid of something, just never thought popcorn was on the list.
View B4B's profile
B4B
163 posts in 2272 days
#8 posted 02-07-2017 03:48 PM
I was in this boat last year. After looking up reviews and putting my hands on some of the cheaper sliders I ended up with the 12” hitachi, I bought a refurbished unit from cpo for about 300, shipped.
Mt thought was I could buy a cheaper saw and be frustrated and buy a better saw, or just save the money, time, and frustration and buy a good saw from the start.
If you are not in any hurry save up the $$$ and get the hitachi or ridgid. CPO does take PayPal, so you could stretch the cost out over 6 months.
-- There's two routers in my vocab, one that moves data and one that removes wood, the latter being more relevant on this forum.
View syenefarmer's profile
syenefarmer
562 posts in 3995 days
#9 posted 02-07-2017 03:56 PM
My son has the 10” Harbor Freight slider and his usage is more carpentry than woodworking. For his usage it works just fine as he rarely needs precise cuts. Him and I recently used it when we installed 1000 square feet of laminated flooring and never had an issue with it. I would suggest installing a good quality blade on it which we did. If you’re looking for a slider that will provide you with consistent high quality results then I suggest you remove the word “cheap” from your search.
View MrRon's profile
MrRon
5954 posts in 4158 days
#10 posted 02-07-2017 08:56 PM
Miter saws and sliding miter saws were intended for carpentry, not fine woodworking. These saws found their way into woodworking jobs due to their small size. Previously a contractor had to manhandle a large RAS to the work site, set it up and re-align it before use. Carpentry doesn’t require the precision that can be attained in a shop environment. Even trim work doesn’t require precision measured in thousands of an inch. Any miter saw can do the job as long as high precision is not needed. Expensive sliding, compound miter saws can approach the precision needed that previously required big expensive shop machines, but for general run-of-the-mill woodworking, the miter saw (any variety) can do the job well.
View dhazelton's profile
dhazelton
2839 posts in 3211 days
#11 posted 02-07-2017 10:09 PM
I would just avoid Sears for the fact that they are closing locations and I wouldn’t feel confident that they will be around much longer.
The Kobalt sliders at Lowes are decent quality and not a lot of money. The small one that takes a 7 1/4 inch blade would be on my list as it is easy to move around.
https://www.lowes.com/pd/Kobalt-7-1-4-in-9-Amp-Bevel-Sliding-Laser-Compound-Miter-Saw/3512783
View William Shelley's profile
William Shelley
609 posts in 2384 days
#12 posted 02-07-2017 10:15 PM
I would just avoid Sears for the fact that they are closing locations and I wouldn t feel confident that they will be around much longer.
- dhazelton
I really liked this one when I looked at the display in the store. However, they were out of stock, so I bought the 10” slider for $199 instead. I really really like it. The manager took off 10% because they were out of stock on the one I wanted.
https://www.lowes.com/pd/Kobalt-10-in-15-Amp-Single-Bevel-Sliding-Compound-Laser-Miter-Saw/3512785
-- Woodworking from an engineer's perspective
View papadan's profile
papadan
3584 posts in 4283 days
#13 posted 02-07-2017 10:18 PM
I have been using the HF 10” sliders for about 18 years now. My first one was left out in a shed that the roof leaked on by my Son, that was in 2011. I bought a new one then and told him to keep that one. Once you set it up correctly they stay set. I got mine for $59 with a coupon and if I need another some day I will buy another HF.
dhazelton
#14 posted 02-07-2017 10:56 PM
Also look at the price of blades before you decide – 12 inch blades are pricy.
JCamp
#15 posted 02-08-2017 12:34 AM
I personally like the idea of a slider I don’t want a 12inch cause I can’t have hardly find blades without a 45min drive. I’m leaning toward the red one over the HF one although if I could get it for $60 I did buy it My work is fine within a sixteenth of an inch Also it might get used once a week on average for a few small cut. I do some contractor style work for myself tho so it’s used more then I’d rather buy a cheap one An put money into a planer or jointer or lathe
