MM, a lot of woodworkers DO use dado stacks. Just because you don't is no reason to claim a ZCI is not needed. I use them to help chipping, especially on melamine, but with plywoods as well.
Never suggest to not use your throat plate, that could get someone hurt. Can you imagine the damage if you accidently caught the blade and it pulled you down into the throat hole?
Most standard inserts are made for 90 degree cuts and angles, so use the standard one if nothing else.
