1 - 13 of 13 Posts
Discussion Starter · #1 ·
Current Situation
Here are some views of the current situation with the garage that I intend to use as a workshop. As you can see, it is in need of some serious attention. It's 3.1m x 6.4m (about 10' x 20') which seemed quite big to me, but now seems tiny by comparison with some of the workshops here at Lumberjocks! This is one of 3 garages, so at least I will have exclusive use of it.
It used to be used as a garage, boiler house and fuel store. Since moving in to the house, I've removed an old oil storage tank and other debris, and fitted some shutters to the empty window opening to keep out the worst of the weather.
Impatient to start (I've been waiting nearly 50 years for a dedicated workshop), I moved in a couple of machines and put up some tool hanging boards and shelves.
However the time has come to try and do a better job, so this post is to record the starting position. Progress will be slow, as I have a number of other commitments, and renovation work to do on the main house (which my better half inexplicably considers more important!). I also have to work to a pretty tight budget - especially given the sterling/euro exchange rate.
Along with the evident cosmetic problems, the roof leaks, the floor is extremely uneven and the electrics are old and unreliable. As well as leaking water, the roof lets in a lot of vegetative debris (the canal tiles allow for very efficient ventilation). This is the reason for the machine covers.
I think the next job will be to deal with the old water heater and boiler flue (shown below). The flue is asbestos, so I think I will be hiding it rather than removing it.
The water heater will go, along with the old plumbing. I will box in the flue, and fit a new consumer unit to supply power and light. I need to deal with the roof problems and then insulate and box out the ceiling. The window at the back needs attention, and there is a load of garden-related junk to move to another shed.
That's all for now, thanks for looking!
Current Situation
Good possibilities! Good shops have started with less! But not much! LOL
A long journey starts with the first step!
Current Situation
This area has great potential, it's 2 feet wider than mine, so you have a little more elbow room.
You can check my blog if you want some ideas. Although I'm not done yet.
Current Situation
The place looks beautiful, when was it built? Looking forward to the projects you get through it!
Current Situation
looks like a great place with lots of potential, (since it's still somewhat empty) - If you compare it with the majority of workshops here (most of them are not posted though) you'll find that yours is actually on the larger side… :)
Enjoy the setting up the shop process, can be a PITA, but can be also just as fun as woodworking sometimes.
Current Situation
Looking good, I admire you so much that you have the space!!! Mine is also a garage about the same size as this one, but have to park my car there, and I am moving out the car every time I use there a my workshop.
Looking forward to seeing your progress.
Current Situation
Do you know how to eat an elephant?
Just one bite at a time. Don't get discouraged. After 50 years you deserve this and the journey may be as much fun as the destination.
I look forward to watching your progress.
Discussion Starter · #8 ·
Current Situation
Wow - thanks for all the comments and support. This really is a great community.
I'm not sure how old the place is - the house deeds don't record anything prior to WWII. I would say probably mid-1800s, but the walls of this garage (in the terracotta blocks) are much later. The wall on the right is patched old lime mortar over stone and part of the original. the garage roof is old too. I think that the garage is probably a rebuild of a derelict lean-to, re-using most of the original roof. The floor is odd - it's about a foot higher than the rest of the house - I think successive attempts at levelling & renovating have been done on top of the old floor. It really needs to come out and have a new slab poured, but too much work for the moment.
Back to eating the elephant…
Current Situation
potential…potential…potential
We were all potential until we sharpened our skills.
That place looks like a diamond in the rough!
Current Situation
much larger than my first shop. Now all the fun begins.
Current Situation
wow you have a roof!!
Current Situation
Well, my first shop was part of a 2 car garage.
Looking forward to seeing your shop take form.
Current Situation
what a beautiful space!
1 - 13 of 13 Posts
