1 - 20 of 77 Posts
Discussion Starter · #1 ·
Glenn Drake saves the day...twice.
I am currently building a small shelf out of Alder and some mystery white wood to house some of my finer tools so that I do not have to go into my larger cabinet to get them all the time. This is part of a larger initiative to keep my sharp tools sharp and accessible, as someone who only uses hand tools most of the time this is about as critical to my work-flow as paying the power bill before someone fires up their table saw. Roughly six hours got me to this point.
I really did not take any picture up to this point because my plan was to finish the project in about 8 hours and taking pictures slows me down (I am a bit of a camera nut), Working with a stolen 15 minutes here and there I was able to get the back panel fitted, which brings us to the reason for this post (but first a picture of the chaos…er work on my bench)
The back panel is made out of the aforementioned white mystery wood. It's not poplar as I first though. It's soft straight grained, smells awful, and is an absolute mystery to plane. It tears out in patches for no apparent reason, when I take a fine cut the result is crap, when I take a rough cut that would leave other woods pockmarked…glassy smooth?
One problem came from this wood and one from limitation of my tools.
I had already plowed the groove to receive the back panel using my Stanley 45 (shelves) and used my 1/4 chisel for the sides since it was a stop cut. Next came cutting the opposite sides of the joint into the back panel. The sides were simple scribe lines saw cuts, chisel a bit for clean up, done. The top and bottom is where I ran into trouble. I only own a 1/4 inch blade for my Stanley, and the rabbet that I needed to create was just a bit to deep for that. I did not feel confident that I could make two cuts accurately as I would eliminate my registration surface with the first cut, I ended up coming up with a faster way. I set my plane to cut to depth on the farthest right side of the joint (establishing the depth and side of the joint).
I then made a scribe line to the same depth as the plow with my marking gauge (a very deep scribe line using the A2 tool steel blade.).At this point I was able to push the extra piece into the joint and SNAP, right to the scribe line. A little work with a router plane cleaned up any inconsistency.
The bottom of the panel is a bit more complex since I have to make room for knots to be accessed through the back (for storage of planes). I made scribe lines and worked a bevel by hand with a smoother and a block plane. If I planed the bevel to the point that it would fit in the groove all the way I would have lost too much thickness, so I made small rabbet with my plow plane. Despite the deep scribe line I left, I got all this stringy crap coming off the back of the joint. I could have left it, this being the back of the cabinet, but I had an idea. I set my marking gauge to the depth of the worst of the tear-out and used my tool to shave away a nice clean edge.
A nice fit…happy shavings.
Aside, I almost always capitalize the names of wood that I am working with. I think of them as people…I'm strange, deal with it..
You're not strange, you're a wood worker!
Great Ryan, it is a pleasure to read your new blog, thanks for sharing. A real project, keep your good work up !
Great stuff, Ryan. I've got some bathroom shelves to get started on this week. I capitalize most nouns on accident, it's a German thing. They capitalize all nouns. I am not German but I took a lot of it in school and I think I wrote more academic papers for German classes than I did for Economics, which was my major.
Ryan,
THat's a cool project. I love how it turned out. I've read it a few times and still don't get how you came up with the title: Glen Drake saves the Day.
Can you explain a bit?
Discussion Starter · #6 ·
The marking gauge I use. (and love.
Discussion Starter · #7 ·
Here, this is the second top of the line tool I purchased (the Titemark). I can say every time I use it I thing "money well spent".
http://www.glen-drake.com/
The marking gauge worked well for cut cleanup and scoring for break-off of waste, this is something that a conventional or lesser quality gauge could not have done. Good tools do what they were made to do, great tools do more.
Discussion Starter · #8 ·
Scraper shave fun
I did not have a lot of energy by the time I got done with everything else that I had to do, so my "mini-roubo" was just a bit out of reach. I still wanted to do something, so I went to the scrap heap and found a piece of walnut large enough to split down to a more straight grained piece.
The goal here is to make a scraper shave, here are the prospective parts in there rough format the now straight grained walnut, a piece of desert ironwood (sometimes the scrap pile really pays off) the knurled screws and bolts and a piece of an old saw from a salvation army store.
we'll see what this turns into.
Scraper shave fun
This is one of those shopmade projects very funny and useful later on, It looks attractive at first sight
Scraper shave fun
Looking good.
On my table is a bunch of brass bolts and knobs, and sketches for some shave layouts…
We are on the same travel now.
Best thoughts,
Mads
Discussion Starter · #11 ·
Now serving 38
I was just so pleased to see how many tools I was able to fit on this $13 piece of 3/4 plywood. Beats the hell out of pegboard.
Thanks for looking.
Now serving 38
Thanks for looking.
I'm with Dennis - push yourself for 22 more at least! :) Nice work.
Discussion Starter · #16 ·
Now serving 38
Thanks for looking.
I do have other tools that I would like to throw on there but I may have to tweak the chisel storage as it currently used too much headroom.
Thanks guys….you put me back to work.
Now serving 38
Thanks for looking.
I love it!
Yes tools for wood should be displayed on wood.
My on my workshop wall I have metal pegboards and hate them, so I can't wait to change this!
Beautiful wood plane in the top right there.
Best thoughts,
Mads
Discussion Starter · #18 ·
Now serving 38
Thanks for looking.
Thanks Mads, that made me smile. I love wrapping my hands around that plane. I have a piece of wenge that I really need to get working on for my jointer. I scored some Cocobolo for a song today and now I will have a VERY long wearing sole for it…but where will I put it? (starts drawing a cabinet)
Now serving 38
Thanks for looking.
Wenge is one of my favorite woods.
Yes a cabinet would look good also.
The plane looks like it's saying 'hold me'!
Mads
Discussion Starter · #20 ·
WWII Era German Handplane
Have you ever wanted something for a solid year without pulling the trigger? Day before yesterday I had to make a quick run into town with my wife and I finally decided this had to come home with me.
This tool was loved. All I did before shooting this was set the wedge. Sharpening an old tool before sale is unheard of in this neck of the woods…but such a treat to come across. I made a point to write a note to the seller and let him know it's going to a home where it's going to get used.
http://www.facebook.com/v/10150486265475229
Not quite used to the hammer adjust for this plane…there is a courting period so to speak where you and the tool learn each others story. Looking forward to getting to know this one.
1 - 20 of 77 Posts
