1 - 20 of 35 Posts
Discussion Starter · #1 ·
Inexpensive Aluminum T-Tracks!
Table Wood Wood stain Hardwood Rectangle
Wood Wood stain Hardwood Netbook Flooring
Wood Hardwood Bicycle part Rim Auto part
Woodworking Accessories Alternatives
Getting woodworking accessories in a country that woodworking is not a common hobby - actually there are no woodworkers here just cabinet makers - even the simplest things have to be imported and off course you have to wait for them.
Importing things from US by the time they arrive here the price number is doubled and that number is in euro now.
Importing from UK is cheaper but not always they have what I need.
From both places very few companies are willing to ship internationally most of them deliver locally, so that's another head ague.
T-tracks are one of those accessories we all use and need but when you can get any, that's a problem. The cheapest one I can get is from UK and will cost me 10.5 euro for 3 feet, that's about 14.5 US dollars.
Then I came up with this idea (product) that is widely available and costs 1/3 of that price.
Curtain rail tracks…
Yes they work perfect, they are made from aluminum, are not thick but it will hold firmly anything and without any deformation. They are smaller is size only for 6mm (1/4) bolts (that's good enough) and anyway I can't get any of those flanged bolts here so I just get normal bolts and grind away the sites, they fit perfect. They do have one advantage that the shape of the T-track is such that there is no need to countersink just screw them with flat head screws.
Here is an example where I used them, on my drill press table.
Try them out and I am sure you will be more than satisfied.
Note: These tracks have been around as far as I can remember in my country. Don't know where and if you can find them in yours.
Steliart, that's a great idea! I've used a special router bit and routed T-track directly into the wood, but this is not very strong. I'm going to try that this weekend.
Thanks for the suggestion.
Discussion Starter · #3 ·
Bovine
Let me know how it goes
Steliart :
I have thought about this idea for a longer time , but always thought the Curtain rail tracks
was too small , in the way I always have truoble with finding screww where the heads are small enoff
to pass thrugh the spur without damaging it and when I find them they can´t hold the Curtains tothe ceiling
so what size of track´s are you using ?
take care
Dennis
Discussion Starter · #5 ·
Dennisgrosen
Dennis maybe we are not talking about the same material here. The ones I use are 15mmx10mm and with an opening 6mm on the top and a 9mm on the bottom. Plenty of space as you can see in my pictures, and there's a 3mm clerance for the screw head.
These rails are very common and used widely and hold alot of weight.
It's so inexpensive that will cost you nothing to try it out at least as a test, I am sure you gonna change your mind about them.
Thanks
Stelios
Discussion Starter · #6 ·
Rectangle Table Parallel Automotive exterior Diagram
Here is a sketch for them.
ive been looking for a t track alternative for awhile, never thought to look in the curtain section at the store, will have to take a look now! thanks for the tip
thank´s Steliart
it isn´t the same track´s I know of
but I will forsure look after those of yours now
becourse they have this exstra little step of deepness inside the track
sothere is room for the screwhead
thank you
Dennis
That is a neat idea! I am in the same boat as you, no fancy accessories availlable here and if you do find them they cost an arm and a leg! Our brothers in the US don't know how easy they have it!
I will definitely check out what curtain tracks are available in my part of the world. Thanks for sharing!
Hey, I'm right here in the US and I'm going to check them out too. I've got a couple of jigs to build and bringing the cost down is always better.
well no such thing at the local home depot, also a search online only shows non-us sites carrying these. are they a european thing only?
I can´t find them either on any Danish site´s
does the profile have a name or number
Dennis
Discussion Starter · #13 ·
Hmm that's the first thing the I can find and others don't, is always the other way arround.
Don't know if it's a European thing only, it has been in the market since I can remember.
I thought that was a standard curtain track!
Look it up as Aluminum curtain track/channel/rail/rod/extrusion normally they come together with there plastic hooks, but has to be that type of profile. Also we can find these in window blinds and curtain shops.
Put the blog in your watch and when I'm better and visit my depo I will try to get some info for you and I will post it here.
thank´s Steliart ,its preciated :)
take care
Dennis
Brilliant.
Thank you for the tip.
As Mike above said; I never thought of looking in the curtain section.
In the US, a great source for these type curtain tracks is Curtain-Tracks.com
You can't usually find them in big box hardware stores, but they are available and those guys have a wider range of sizes.
i looked in the local walmarts and hardware stores but could not find them. is there a store that sells these?
Discussion Starter · #18 ·
Kerf Setting Dado Jig from a T-track left over
Rectangle Gas Font Technology Output device
Continuing this blog on T-tracks, there is nothing that goes to waist, even the most insignificant piece, at a given moment may turn out to be gold.
So, the other day I was looking into some drawers and I found a cut-off piece of t-track that I used on my router table. We all use them and most times we cut them to size to fit our dimension, as they are sold in specific lengths. So I was thinking why did I save that small 20cm long piece?
And the same night as I was browsing along the woodworking sites I saw this Kerf and it hit me what could I do with that left over piece of T-Track.
So I sat down and CAD a design of a Kerf Setting Jig using a piece of T-Track and some pieces of wood. Here is how I used that "useless" left over piece of T-track to build the Kerf Setting Jig.
If you wish to read more on how to build this jig, its dimensions, see some SketchUp photos and how to use it and set it up, please visit my Projects.
Thanks
Steli
Thanks
Steli
Cool! I knew I saved those "scrap" pieces for something!
Thanks
Steli
looking good on the drawing
but I can´t see the adjustment screw
thats compensate for the sawkerf
take care
Dennis
1 - 20 of 35 Posts
