1 - 5 of 5 Posts
In Loving Memory
Discussion Starter · #1 ·
Wood Library - Basswood
Basswood - Tilia americana
If you love to carve then this is the wood for you. It has a cream color with very little to no pattern from grain so you can cut it in basically any direction. Very easy to carve.
It's not the greatest for machining and tends to rip or crush under the pressure of a cutting tool and when sawn it leaves a fuzzy or woolly surface. It's also not very strong and tends to break into small pieces.
One of it's best attributes in addition to it's carving characteristics is it's stability. It tends to maintain it's shape. That's one of the reasons that it's used for making the keys in keyboard instruments.
Best of all is that it's inexpensive.
thanks for the info Gary. I've always heard carvers rave about basswood but i didn't know that it didn't machine well. thanks for the info.
Gary, have you thought about putting pictures with the wood library blogs?
Hi Garry
I really appreciate the work you are doing with this series on different woods - I think it is great. Acouple of suggestions if I might.
Include the Latin name for the species you are talking about - This helps for regional names for the same wood.
How about formalizing the information and layout, such as a table with various headings, so the same information is in the same place all the time - and if you are missing some information, then others can also do some research to fill in the gaps. Maybe Martin could formalize the information and give it its own link, maybe under reviews. Keep up the good work -
Gary:
Every so often I am going through some wood i got as Maple and I run across a board that has a rough surface. I guess it might be basswood, because of the description that you stated.
Thanks for the ingo.
1 - 5 of 5 Posts
