I'm going to say cheap Chinese metal.
+1SPAX or GRK
- gtrgeo
After you use GRK Screws you will be amazed and swear off true lags.I agree with the cheap Chinese metal. I have had the same issues with the lag bolts like you are using. I have gone to using the SPAX or GRK lag bolts and have found them to hold up much better. They cost a little more but are well worth it.
- gtrgeo
lubricant, and drill correct hole size, we use the snot out of them, no issues, other than an occasional mishap like this,
and as noted lotsa other options also,
what amazes me is that folks do this to the bottom chord of a truss that is meant to hold no more than a few pounds per sq ft and load the sucker up with a lot of weight, heres hoping the truss manuf. did a good job
Rj in az
- Knockonit
</blockquote
He said Joist, not the bottom of a truss. He also said 2×10. Makes me think these are floor joist over his garage, for a room above
https://findanyanswer.com/how-much-weight-can-i-hang-from-a-floor-joist
[/QUOTE]lubricant, and drill correct hole size, we use the snot out of them, no issues, other than an occasional mishap like this,
Rj in az
- Knockonit
