1 - 16 of 16 Posts
a lady i work with wants me to recreate some antique porch swings for her. ive been thinking about her requestes of strong, durable, and mostly maintenance free. i was thinking white oak would fit the strong and durable, but not the mainenance. then cypress, but thats not strong. nor is cedar. so that lead me back to white oak.
anyway, can white oak live outdoors in NC with minimal maintenance?
Michael
In Loving Memory
White oak is an excellent exterior wood, it ranks right up there with cypress , the only thing I know of that is stronger and does well in outdoor environments is IPE , white oak left natural will grey , a seasonal washing with some clorox in a 50/50 mix with water will restore it ,but I would use a good exterior oil like general finishes exterior oil , or a pure tung oil, ( tung oil will dry slow), a film finish will still allow the greying, you can also check to see what your local suppliers are using for cedar siding and roofs.. and that will work as well.
here in the mountains of Virginia , we have what are called "pig fences" , they are basically a low split rail fence that were built a hundred or more years ago, they are white oak, they are grey , covered in moss , if there is some sap wood it may have decayed some what, but you scrape away the ugly and they are still sound and solid…
Can you get IPE in your area? I used it when I rebuilt these garden benches a few months ago and it looks great. I left it unfinished, and I'm told that it should stand up to weather for many years.
I built an ipe deck 12 years ago and I have made all of our outdoor furniture out of ipe. It is a great outdoor wood (if you can get it).
Regarding white oak - - Many years ago a lot of farm equipment was made with white oak because it held up for the long term in the weather. I have an antique horse drawn plow that we use as a decorative accent in the yard. It's at least 80 years old and the handles (made of white oak) are still pretty solid. If I had a couple of horses I could still plow with it today.
I'll jump on the Ipe bandwagon (also called Brazilian Walnut). It's great for outdoor furniture, and has a dark, rich color and may not even need to be finished. It's readily available at hardwood flooring suppliers. If I ever build us patio furniture, it'll be Ipe. One caution, the sawdust is pretty hazardous, so use dust collection and a mask. The bistro table in my projects is made of Ipe.
I have used White Oak for several outdoor projects over the past 7 years and they are all still in great condition. There is very little maintenance required. We get the heat and humidity in Maryland that you get in NC just not as long so I think it is safe to say that you would do ok with the species. White Oak's pores are filled with tyloses which acts as a water repellant. Most wine barrels are made with White Oak for this reason. I think this is the best domestic outdoor wood. There is no question that the tropical species are even more rot and water resistant, but you can't beat white oak as a North American option. Think of it this way, most our this country (and England) was built on White Oak.
In Loving Memory
Spanish cedar is an excellent exterior wood , but personally think it too soft for a swing or anything else that has to bear weight, its like you said its very similar to mahogany in density , a bit light for chairs and swings… I have repaire more mahogany chairs than other species… just too soft.. for structural components , basicall like white pine… just my opinion
I have access to copius ammounts of white oak AND cyprus!
Got to admit it: White oak is an awesome exterior wood that weathers great! It is extremely heavy, though. And it can be somewhat unforgiving to work with.
Cyprus is very light weight and easy to work. However, it is not nearly as hard as white oak, but it does ding up if roughly treated. It takes paint much better than most, if not all, other natural woods.
In Loving Memory
I find White Oak a pleasurable wood to work with. It machines very well and is very smooth right off the planer. I haven't worked with Ipe' but I understand it is about the best outdoor wood around. Since they are both good choices I would choose on the basis of color and what kind of grain you think appropriate for the job. A good marine varnish is the best finish for both. Good luck with your project.
hi dear,
Oak is commonly used in furniture making. Both red and white varieties are strong, with hardness grade of 4 on the same scale, although they are still easy to work with. Also, it has a ray flake pattern when cut, making it a beautiful material for furniture. White oak is preferred by woodworkers for outdoor furniture because of its resistance to moisture and its attractive figure.
funique
1 - 16 of 16 Posts
