1 - 13 of 13 Posts
Due to the size of a table top I'm working on I can't square the ends on my table saw so I need to do it with a circular saw.
What is the blade of choice for crosscutting 1 1/2" thick walnut and ash? Carbide, hss, or regular water hardened steel?
The blades I have for my circular saw currently are somewhat dull 7 1/4" diameter ripping blades that I don't think will leave me with a clean cut. I have looked into the blade guides on different sites but I have not found any info on a blade dedicated to crosscutting hardwood cleanly.
Thank you for any help and your time in advance.
Kevin
This is the table top I'm working on:
Wood Composite material Gas Flooring Hardwood
You could always rough cut it and then run a router with a straight edge, and straight bit, which would make it smooth as glass. Just make sure you have a sacrificial piece on the end. Hope this helps
+1 on Kaleb's method. The method of cutting you propose is excellent for rough work and can get you within tolerance for the routing step. Get a nice long bit, a straightedge and go for it!
Font Circle Logo Graphics Label
Freud sells a Diablo finishing blade, available at Home Depot, for $14.
It does a remarkable job of trimming tabletops. I find that with this blade, there is no need for any further trimming with a router.
Good luck.
I second the Diablo blade. Routinely use one with my circ saw/guide system for plywood with minimal to no tearout.
I know you're getting the router bit, you and alternative would be a low angle plane to touch up the edges.
Assuming you'll put a slight chamfer or roundover on the edges, any minimal tearout is not problem.
Good luck.
- pintodeluxe
+1
Great blade and a great price.
1 - 13 of 13 Posts
