Finally felt good enough to get back down to the shop and do a little something to further things along.
So
this is the table I am in the process of making. (That maple is gorgeous but I don't currently have any)
I am obviously using different woods, but I'm also changing some of the proportions, slightly.
I had originally started to mill the legs in QSWO but then decided to use some walnut that I have for quite a while that has a nice curl in the figure. I'm using Dominos vs M&T for simplicity.
I have a suitably sized piece of walnut for the top, but I may be digging into my walnut stash and gluing up a top that has the same curl in the figure. Been waiting on a project for this nice board, but it may have to wait a bit longer.
This is the jig that holds the template for the double curve in the legs.
It's two-sided and all four sides of each leg get milled using this 2"x7/8" compression bit. Makes an amazing sound when spinning at 20k rpms lol
The jig for the leg took a bit of fine tuning. Even though the authors plans are pretty complete, there were some areas that were not explained well. The one leg I have milled I finished with a draw knife, block plane and card scraper. I used that to go back to the jig/template to refine it. I think it's where it needs to be to produce the legs accurately.
So far it's been a fun project. Heck the jig/template was a project in itself. I think I already have another project I'll be using it for, so not a one off use
