Hard to answer with out more info on the blank. It the groove in the bottom or top? How thick is the blank, it looks to be about 5" in diameter. I have some concern about the crack. Did the person who gave it to you explain anything about it.
the blank is close to 10" diameter and about 4" deep, the crack is not a problem the blank is dry I know nothing about the blankHard to answer with out more info on the blank. It the groove in the bottom or top? How thick is the blank, it looks to be about 5" in diameter. I have some concern about the crack. Did the person who gave it to you explain anything about it.
yea there is enough room for dowelsMyself I would be very concerned that it could fly apart given the current condition. Even if you could fill the crevice with epoxy you will open more areas of the crack as you remove material. I would not take a chance with this your safety is worth way more.
calabrese55
