1 - 9 of 9 Posts
Discussion Starter · #1 ·
Tuner Head Inlay
Well, I am in the process of my first attempt at a guitar, and I have decided to go with Walnut to build it out of. I am designing it somewhat similar to a Les Paul, but I am putting my little twists on it here and there.
As they say, when it rains it pours. I guess that applies here as well. Because I attempted my first inlay today. It isn't perfect and there are some spots that need a little filler but I think for my first attempt I did fairly well.
I first sawed off a couple pieces of maple and then a piece of ebony. Once I sanded those down and glued them together, I cut off thin strips which I then cut with a razor blade to fit my template. Once the glue dried, I sanded it down flush and this is what I came up with.
I have the truss rod on the way in the mail, and hopefully I will get it in soon along with the fret board. I am thinking of using some curly maple. I just need to find a really nice piece.
Tuner Head Inlay
Looks good. Keep the post coming of your progress.
Tuner Head Inlay
pretty darn good
Tuner Head Inlay
Can't wait to see finished job. Good work.
Discussion Starter · #5 ·
Tuner Head Inlay
it was pretty nerve racking to cut into perfectly good looking wood to do this, but I am pleased with the result.
Discussion Starter · #6 ·
Tuner Head Inlay
I have been following your blog Autumn… I think my biggest problem with my inlays is the fact I am hand chopping them out with a chisel instead of using a router like you suggested in your blog.
I recently finished a pair of gun grips for a friend that I inlayed an ebony diamond over each screw hole… I plan on posting a project once he gets them mounted on his Kimber, and sends me the photos. Bloodwood is a difficult wood to hand chop LOL.
Discussion Starter · #7 ·
Fretboard
I received an email stating that my truss rod was delayed in mail, so I cannot move as fast as I was expecting to on this portion. But it did give me a chance to go pickup a piece of maple for the fretboard and lay it out to give me the best look. The maple has a little curl to it, so hopefully once I get it polished out It will look real sharp with the contrasting walnut neck.
Also, i have cut out blocks that I will start gluing up to create a radius-ed sanding block for the fretboard, it will have a 12" radius. It is cut out of 6 MDF pieces and once I glue it and true it, I'll have a stable block to get the board just perfect.
And here is a shot of my helper :)
Fretboard
This is a really neat project, glad you are blogging it. Cute kid!
Fretboard
Good blog keep up the good work.
1 - 9 of 9 Posts
