1 - 18 of 18 Posts
Discussion Starter · #1 ·
Door Progress
I didn't have much time in the shop this weekend. We're getting ready for our Passover seder and my college softball team had a double header today, and I couldn't resist spending a little time in the sun.
In the shop I worked on the sizing the strips which will hold the panels in the doors of the wall cabinet (see project posting).
The doors have a rabbet that runs around the inside of the door to hold the panel. To hold the panel from the back I'm using strips that will be pinned in place with brads.
I finished cutting the miters in the strips for one door. I may have to narrow the strips, so that the door handles and hinges will fit. I'll decide on that the next time I'm down in the shop. In the oops category I discovered that I miscalculated and didn't cut enough stock for both doors. The source of the miscalculation is the miter. I forgot to calculate the lengths based on the outside of the strips, rather than the inside.
Door Progress
been there
Door Progress
I made a box, REMEMBERED to include the extra length for a mitred edge….
and then said, "why are these sides so long? That's not right… and then cut them off"...
(shaking my head at my brain goof)
Discussion Starter · #4 ·
Completed Doors
I finished the doors for the wall cabinet earlier this week. The frame is maple, the panels walnut.
Here are the two doors. If you look closely you might be able to see that the panels are bookmatched.
The inside of one door. The mitered retainer frame is glued and tacked to the inside of the door frame. The color variation in the upper right corner is the result of a measuring error. When I cut the pieces I used the inside measurements of the frame, not the outside. So, I had to use some extra stock to fill the gap. I'll have to work on evening out the color when I finish these.
Next up is assembling the cabinet case. This requires a visit to the big orange store - I am going to attach the back to the sides with brads and I don't have the correct size. I hope to have the construction phase of this completed this weekend.
Completed Doors
Gorgeous!!!
Completed Doors
Looking good.
Discussion Starter · #7 ·
Case Assembly
Over the past several days, I completed the assembly of the case for the wall cabinet. Material is maple except for the panel in the back, and I made that so long ago that I don't remember what kind of ply it is.
The back sits in rabbets in the sides and is secured with screws. I had to make a visit to the big orange store because I didn't have the size screws (#4). The back panel has mortise and tenons between the rails and stiles.
The sides are attached to the top and bottom with pocket hole screws. I made a slight error in laying these out. I placed them a little too close to the back which made them difficult to secure. I'll be plugging the pocket holes with maple plugs. Oh and if you look closely you might see the plugs in the mis-cut shelf pin holes.
The doors will sit between the sides.
Tonight I fit the doors - a fair amount of hand planing and sanding, and started work on the hinge mortises - one down, 7 to go.
Case Assembly
Looks like your making good progress. I'm looking forward to seeing the finished project.
Case Assembly
Lookin good… Do you have a Kreg pocket hole jig? Or do you do them by hand?
Drew
Discussion Starter · #10 ·
Case Assembly
I do have a Kreg pocket hole jig. I bought it on a whim at a woodworking show several years ago and I've got to say it was well worth the cost.
Case Assembly
Nice job.
Case Assembly
Great views.
Discussion Starter · #13 ·
Hinge Mortises
I'm closing in on completing the construction of the wall cabinet. Progress this past week has been on the hinge mortises. I've got the mortises in the doors done, as well as two of the four in the case.
I'm cutting the mortises by hand - using a marking gauge to mark the depth and width and doing the rest with a chisel. It's slow work - the door frames and case are maple, after all, but satisfying.
Here's a picture of one of the mortises, with the hinge in place.
Hinge Mortises
that's pretty precise!! nicely done.
Hinge Mortises
...it looks good.
Hinge Mortises
Just yesterday I worked a hinge into a case. It is very satisfying to go slow, take time and allow the wood to inform you as to what to do.
Hinge Mortises
Very nice!
Hinge Mortises
Nice job!
1 - 18 of 18 Posts
