Vega U-26 Tablesaw Fence Not Locking Properly
1699 Views 31 Replies 6 Participants Last post by  TheBossQ
I did ask this last night and didn't get any response so I'll try again. I need to use what seems excessive force when engaging the main fence lock. If I don't do this the fence wanders out of adjustment. Any tips or tricks would be greatly appreciated.
1 - 20 of 32 Posts
I'll have to look at the locking mechanism on my fence tonight and refresh myself on how it works. I do recall that there are some nylon pieces that hug the back of the rail and the locking cam hits the front and pulls the nylon tight to the rail. It sticks in my mind that there is some adjustment for the nylon pieces to account for wear but I could be mistaken. I'll try to look this evening and report back.
There is a brass tab between the handle cam and the guide bar and I'm wondering if it is a hair too thick
For information sake, the fence was purchased new just 2 months ago.
Ahh in that case, it's definitely not wear. Now that you say that, isn't there a screw opposite that brass piece that you can adjust in/out to adjust the clamping force?
It may just be an issue of needing some use to break it in, so to speak.
6
Okay, I flipped mine over and had a look. You can see that the brass on mine is well worn for sure.
Bag Sleeve Wood Material property Handgun holster
However, this is the screw I was talking about that should allow you some adjustment as to the clamping pressure.
Wood Automotive exterior Bumper Gas Machine tool
If you loosen the jam nut and thread that screw in a little further, it should relieve some of the pressure. As the brass wears, you may find that you have to move the cam a little further to lock it. Then you can back that screw out a little bit to account for the wear to the brass.
For reference, this is about the position your cam should be in when the fence is locked tight. That's the peak of the cam profile. If you can't rotate it pretty close to that position, then it is possible that vibration from the saw and pressure applied to the fence are causing it to loosen up a bit.
Wood Tool Kitchen utensil Gas Saw
Hope that helps!
Thanks for your help Ken. Looks like my locking system is very similar, it appears that I may not have the ability to adjust the tension.
Bicycle handlebar Wood Surveillance camera Bumper Automotive exterior
Well I'll be danged. Looks like they've changed the design siginifcantly. Sure doesn't appear that there's much you can do besides maybe sand the brass piece a little bit.
2
Here is a look at the cam, the machining looks a bit sloppy.
Wood Door Fixture Material property Gas
Yeah, there's no reason the cam profile needs to be precise though and it's doesn't need a smooth finish so that shouldn't be a problem. At least on the style that I have because I can adjust for some variation. On your design though, if it's too big, well, you're gonna have the problems you're having…
Have you tried contacting Vega and seeing what they have to say about it? Their phone number is (217) 963-2232.
If there is no adjustability, you could place a strip of UHMW "drawer glide" tape along the fence rail where the two are "squished" together when clamped. It'll take up about 0.020" of the gap. Come to think of it, you could add it to just the face of the brass or use some PSA sand paper with a fine grit to let it grip good-n-tight.
If there is no adjustability, you could place a strip of UHMW "drawer glide" tape along the fence rail where the two are "squished" together when clamped. It ll take up about 0.020" of the gap. Come to think of it, you could add it to just the face of the brass or use some PSA sand paper with a fine grit to let it grip good-n-tight.
- splintergroup
True except I think he needs the opposite :) Sounds to me like there needs to be a little MORE gap between the rail and the cam. Or a little less brass…
- 18wheelznwood
This definitely should not be the case. The fence is a safety device and shouldn't need anything to work properly.
The machined face opposite the cam, is it just dirty? I can't tell if the marks I'm seeing are wear marks. If so, it looks like that face is intended to lock on the backside of the chrome rails (assuming they still make them of chrome). And that machined face is only making contact with the rail in a couple of small spots.
Maybe take some automotive sandpaper and sand that a bit so that more surface area makes contact with the rail.
Ahh, so you mean the lever needs to turn down further/tighter?
Odd that there isn't some kind of adjustment point for that. Could the cam lever be installed upside down and cause the problem?
The fence is only a couple of months old and the problem is that I have to apply excessive downward force to get the lock to engage fully
Take the fence off and swing the lever until you see the brass piece move as far as it will move. That should be the position you handle is in when you lock it on the rail. Now lock it on the rail and see if it comes up short of that and how much. That should give you an idea of how much you need to tweek your pressure and validate that the brass is too thick as I suspect.
4
This is fence on the rail handle down to where it begins to engage the brass pressure plate.
Automotive tire Bumper Automotive exterior Trigger Gas
Now this is fence off the rail and cam fully engaging the brass plate.
Gas Engineering Wood Machine Automotive tire
That seems to be a fairly good difference.
It's not enough I don't think. Of course your cam may be completely different. In any case, if it comes loose while you're using it, it isn't working right. I think my first step would be to call Vega.
1 - 20 of 32 Posts
