turnings
63731 Views 135 Replies 47 Participants Last post by  gfixler
21
from ficus log to turned bowl preform
This past Sunday I decided to saw a Y-shaped Ficus log in half and get some bowl blanks out of it. I couldn't fit the 14" section under my band saw's 12" vertical clearance, so I just cut the first half, up to the Y split. Then I spent about 20-30 minutes sawing through the Y with my 24" carpenter saw. Good workout!
I could fit a 10-7/8" circle on each log in the Y area, which I wanted to try turning for the twists in grain and color.
I had to give up for the night, and I'm tired of everything I look at splitting and checking, so I'm just coating every cut face from now on. I have a bunch of planks that had no checks, and which I sealed on the ends, and they split completely in half, right down their middles. What a pain.
10-7/8" diameter circle:
I sawed the ends off the log, and the corners, to start the circular shape, then screwed it to a board so I could prop it against my recently-made, and taller baltic birch fence. I didn't want the log spinning on me. The board would ride on its edge on the table and up against the fence. Now I had a flat on both sides.
Here's the back of the temp plywood rig. The deck screws go into the center of the side that will be the inside of the bowl, so they'll be turned away eventually. This plywood rides up against the fence, and the bowl blank on the other side has its widest edge sitting flush with the table top:
With the flat, I was able to saw it into a decent circle. Here it is with the other pieces I got out of the same log:
And a big bowl blank emerges:
And until I can turn it, I've sealed it entirely:
Meanwhile… I wanted to see what I could do with this little chunk:
This wasn't the shape I was going for, because I'm still learning how to control my tools. This just sort of emerged after a few slips and fixes:
And AS EVER, some checks. Unbelievable. They're just unavoidable for me. Actually, the end of the log was checked, and I think this piece came from down there. I don't know if ficus is even stable enough to fill.
Another problem with ficus is what I believe to be mold. It's a crappy wood for woodworking, but I do have a whole tree of it, and it is good scrap for learning how to resaw and turn things without ruining the good wood.
This is how I had it chucked, if you were wondering:
Had to stop for the night, so more sealing:
Yesterday I was able to turn a groove in the bottom so I could slip the jaws of my chuck into it and flip it around to turn the inside of the bowl. Here's that groove:
This was the first time I was able to easily turn the inside of the bowl, through a combination of the right tools, the right angles and roll of those tools, and proper pressure, cut depth, etc. It felt good to see some improvement in my skills finally.
I turned it very thick so it will hold shape better over the next few months as it dries. Honestly, I'm not sure it'll even hold up, but we'll see. Once it's dry, I'll chuck it again and turn it to its final, thinner, deeper shape.
I've decided to pick up a free shelving unit whenever I can from craigslist (an online classifieds that has a popular branch here in LA) and put it in my office at work. I can bring my turnings in to sit on the shelves there, acting as decorations and conversation pieces all in one. Then as each dries, I can bring it home and finish turning it, and apply a final finish to it. At any rate, this bowl won't be back in the spotlight for awhile. Wish it luck.
121 - 136 of 136 Posts
first hollow-form failure update - major checking!
Just an update on this post. When I left off, it looked like this:
I took a week's hiatus - no motivation - and upon returning to the garage (last Sunday), I found this:
Note it goes right to the pith, as every check I've seen in any log, branch, or twig in which I've noticed any checking does. This is why so many people remove the pith entirely from their blanks, and why pith-in end-grain turnings can be a bit of a craps shoot.
Note that this was completely green lumber, and turning this thing all the way down, instead of a mere 2" may have helped , as it would have effectively removed the pith over a much greater length, but still… The other probability here is that because this was a branch, and didn't grow straight up and down, it probably had internal stresses that originally helped it counteract gravity.
Here's the bottom - note that the check finds the pith again on this side, and there's a second one, too, which is very common in checking logs:
And this is the part I turned away after realizing it was just way too long. This was sitting on my router table, and checked the same way, right from the pith out:
With the checking, deep, fuzzy tearout which is really hard to manage, and rampant mold control issues, you begin to see why I have such a hard time finding any turnings - or anything - made out of Ficus wood online.
Anyone need about a half cord of this stuff? ;)
rough turn then soak in denatured alcohol for 24 hours no cracks & no distortion wrap in brown paper bag up to over rim tape up place upside down on rack for 2 weeks then it will be ready to finish
Wow, hunter. That is quite a specific procedure! Does the alcohol replace the water and then evaporate more quickly from the cell walls? Where did you hear about this technique? I've not heard it yet. I'm intrigued.
Gary, in case you haven't looked into it more yet, here are a few sites I've looked at in the past on alcohol drying. Great info and it looks like it works although I haven't tried it yet. Hunter summed it up well.
http://alcoholsoaking.blogspot.com/
http://www.wnywoodturners.com/articles/alcodrying/alcodrying.htm
Thanks, Dale! This is an exciting development in my wood turning and drying exploits. I'll have to check - I think I just picked up a gallon of denatured alcohol the other day, though it might have been mineral spirits. I'll get a gallon or two if I not, find some nice tupperware containers, and give this a go. I also have a very large roll of brown paper that's been looking for a use for years, as well as about 6 rolls of masking tape that I've not gotten around to opening in over a year now. I might just have all the materials on hand to experiment immediately. Thanks to you and hunter both for my next series of experiments!
the alcohol makes it dry very quickly evaporating moisture i do it all the time also you can use it (denatured alcohol) over & over again when you soak roughed out bowl make sure to cover the top of container the alcohol will evaporate. mixed woods in alcohol will not stain other wood
a cheap plastic trash can works better if alcohol does not fill above roughed bowl add a piece of scrap wood in to raise alcohol level
check bowl in about 2 weeks if alcohol smell is gone open your present and finish it send me a picture when your finished with it
I'm going to try this too. Thanks for the links above.
15
A small juggling pin
Been awhile since I posted anything! How's everyone been? Work keeps me busy all the time anymore, but I do love it. Unfortunately it's a very long drive, about 45 minutes to an hour in the morning, crawling along LA's 405 and 101 freeways. Traffic ever since school started keeps it really busy until midnight, and with all the techy stuff I'm always working on, I tend to stick around at work until after 8PM, and often until 9 or 10, then the long drive home in heavy (but relatively light) traffic.
Anyway, at a little outdoor games party awhile back at work, one of my coworkers - Ryan - brought in his juggling clubs. I'm a juggler, and I've had this cheap Jugglebug set since I was in high school back in the early 90s. I've been keen to pick up some really good pins from somewhere like Dubé, especially their Europeans. Ryan's pins looked a lot like their stage style clubs, so I was anxious to try them. Here's Ryan juggling them:
The Europeans are ~$45/club, or about 6x the cost in total (for 3) as my old cheapy Jugglebugs. I don't juggle enough to warrant that, especially without getting to try them out first! I could try them out in NY at their store, but I'm in LA. Ryan got his clubs while on vacation in Italy, but has no idea what brand, if any they are. The balance was quite odd for me, and the handles really felt like they were swinging around a much wider arc, almost hitting me in the face with every throw.
There are optional lengths, weights, and diameters on balls and clubs, which makes it even harder to choose online, and then getting to try out the first cool-looking set I've seen and having them be so hard to control just makes it even less likely I'll shell out money to test out what seems like a good combination online. History has taught me that anything with an ergonomic element that I order online I will hate once I get my hands on it. A perfect example is the Happy Hacking keyboard, meant for programmers, but I didn't like anything about it. The keys were way too tall, tapered too sharply (making them feel too separate from each other), too hard to press, and the surfaces felt like 320-grit sandpaper, quickly irritating my fingers. I type 90WPM on average, but I couldn't use any of my shortcuts on that board, like sliding from one key to an adjacent one to type both in one swipe.
Anyway, I've been thinking for at least a year that it would be fun to make juggling pins on my lathe. Bowling pins are (or at least were) all wood. I wouldn't want to juggle all-wood pins for any length of time - my set already kills my knuckles, and they're hollow plastic - but I could make some really beautiful, decorative pins with glued-up hardwoods. I know my mom would love a set for decorating. There are also fighting clubs (Rule #1: You don't talk about fighting clubs!), like these from India, c. 1920.
Too, I could make various pin shapes out of wood, paint them with something to get them smooth and perfect, then make molds from those and do some roto-casting with plastic to create hollow, unibody pins of my own design. I'm anxious to try that one day. Who knows? Maybe I'll make some signature pins worthy of selling under my own brand. In the meantime, though, I figured I should try turning a pin on my lathe. Tonight, home early from work (holiday time half-day), I grabbed a large branch of jacaranda, a great, light wood that carvers love to whittle, and which I have in abundance at the moment:
I started with a 20-inch piece, but soon realized that my 12×20 lathe can't handle a piece that long. I'd have to make a short club - something like a cudgel - and one day upgrade with a bed extension for doing full-size clubs. Fair enough. I cut the piece down to 18 inches and moved the tailstock out to the end:
And now for some turning:
My tools need some sharpening some day when I have time, and Jacaranda is soft and flexible, so I was getting heavy vibration as I thinned the handle. I had to invent new techniques, like taking fast slicing sweeps to the side with the tools. It wasn't very thought-out. I just decided to make a pin and ran out to the garage to do it :)
Here it is all rough. I would clean up the rest with sanding.
All sanded up:
And my hand for scale - it's a mini club.
I cut the ends off with a thin pull saw, then sanded the ends flat with the the belt sander, cleaning up the ends with some hand sanding.
You can see some of the tearout that comes with the territory when manhandling jacaranda. The big chunk in the middle is from turning on centers. The spurs of the driver pin tore it out early on.
A little more tearout on the knob:
I always like bark inclusions.
It was great to get back out there and make something again in the hour and a half I had free. It's been too long. Now I have a new thing to bring in and show my fellow juggling coworker. It was a successful first test, though I probably won't have any more time this year to do another. I will be in the shop this weekend, but Saturday is all about helping my friend make a headboard for his wife for their bed for Christmas (surprise present!), and Sunday is making some things out of branches that have a special meaning for my stepdad for a Christmas present. Then next week I fly home to see my folks until after the new year. Busy times!
And I haven't made a nice mess like this in far too long!
All sanded up:
Now for two more.. and you too can be a juggler…
All sanded up:
good you got some time
back in the shop gary
all that wood you have stashed
must be getting closer
to dry by now
have a great holidays
and hope you get time
next year to have some fun
that sawdust looks better
than the glop
you had on the floor before
be safe
enjoy
All sanded up:
What, no pictures of you with 4 pins in the air- at the same time!!! ;^)
Nice job, Gary.
Lew
All sanded up:
Gary, Glad to see you made it into the shop for a little bit. The bark inclusion on that looks pretty cool. Hope you get a chance to make a few more sometime soon.
CtL
All sanded up:
I've really missed your posts. Good to see you got a little shop time in. Hope the job is still as awesome as before!
All sanded up:
I've been missing your posts too, Gary! Glad to see you back. I hope you go on some more urban logging adventures soon. :)
All sanded up:
I've missed you folks, too! And timjr, I need to go on whatever the opposite of a logging adventure is. I have WAY too many logs for this little 0.18 acre lot now. It really looks like the woodworking version of that hoarders show.
